Menu
Node.js integration for Grafana Cloud
Node.js is a JavaScript runtime environment that allows execution of JavaScript code outside a web browser.
This integration includes 1 useful alert and 1 pre-built dashboard to help monitor and visualize Node.js metrics.
Before you begin
This integration monitors a Node.js app that exposes metrics through prom-client.
In order for the integration to work, the prom-client should be installed and the default metrics should be enabled. Afterwards the metrics can be exposed under /metrics endpoint.
JavaScript
import express from 'express';
import { collectDefaultMetrics, register } from 'prom-client';
collectDefaultMetrics();
const app = express();
app.get('/metrics', async (_req, res) => {
  try {
    res.set('Content-Type', register.contentType);
    res.end(await register.metrics());
  } catch (err) {
    res.status(500).end(err);
app.listen(4001, '0.0.0.0');
Install Node.js integration for Grafana Cloud
  1. In your Grafana Cloud stack, click Connections in the left-hand menu.
  2. Find Node.js and click its tile to open the integration.
  3. Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Node.js metrics to your Grafana Cloud instance.
  4. Click Install to add this integration’s pre-built dashboard and alert to your Grafana Cloud instance, and you can start monitoring your Node.js setup.
Post-install configuration for the Node.js integration
After enabling the metrics generation, you must manually add the snippet provided to configure Grafana Agent to scrape your Node.js application.
The prom-client lib exposes a /metrics endpoint. To scrape it, add the provided snippet to your Grafana Agent configuration file.
Make sure to change targets in the snippet according to your environment.
Below metrics.configs.scrape_configs, insert the following lines and change the URLs according to your environment:
yaml
    - job_name: integrations/nodejs
      static_configs:
        - targets: ['localhost:4001']
      relabel_configs:
        - replacement: '<your-instance-name>'
          target_label: instance
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Node.js integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
yaml
integrations:
  prometheus_remote_write:
  - basic_auth:
      password: <your_prom_pass>
      username: <your_prom_user>
    url: <your_prom_url>
  agent:
    enabled: true
    relabel_configs:
    - action: replace
      source_labels:
      - agent_hostname
    - action: replace
      target_label: job
    metric_relabel_configs:
    - action: keep
      regex: (prometheus_target_.*|prometheus_sd_discovered_targets|agent_build.*|agent_wal_samples_appended_total|process_start_time_seconds)
      source_labels:
      - __name__
logs:
  configs:
  - clients:
    - basic_auth:
        password: <your_loki_pass>
        username: <your_loki_user>
      url: <your_loki_url>
    positions:
      filename: /tmp/positions.yaml
    scrape_configs:
metrics:
  configs:
  - name: integrations
    remote_write:
    - basic_auth:
    scrape_configs:
      static_configs:
      relabel_configs:
  global:
    scrape_interval: 60s
Dashboards
The Node.js integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
  • Node.js
Node.js application overview dashboard
Alerts
The Node.js integration includes the following useful alerts:
AlertDescription
NodejsDownCritical: Node.js not up.
Metrics
The most important metrics provided by the Node.js integration, which are used on the pre-built dashboard and Prometheus alert, are as follows:
  • nodejs_active_handles_total
  • nodejs_active_requests_total
  • nodejs_eventloop_lag_p50_seconds
  • nodejs_eventloop_lag_p99_seconds
  • nodejs_eventloop_lag_seconds
  • nodejs_external_memory_bytes
  • nodejs_gc_duration_seconds_count
  • nodejs_gc_duration_seconds_sum
  • nodejs_heap_size_total_bytes
  • nodejs_heap_size_used_bytes
  • nodejs_heap_space_size_used_bytes
  • nodejs_version_info
  • process_cpu_seconds_total
  • process_cpu_system_seconds_total
  • process_cpu_user_seconds_total
  • process_resident_memory_bytes
  • process_start_time_seconds
Changelog
md
# 0.0.6 - July 2023
# 0.0.5 - December 2022
* Update mixin to latest
  - Add missing job selector to query
# 0.0.4 - October 2022
* Update mixin to latest version:
  - fix NodejsDown alert definition
# 0.0.3 - September 2022
* Update dashboard panels descriptions.
# 0.0.2 - October 2021
  - Update queries to use $__rate_interval
# 0.0.1 - December 2020
* Initial release
Cost
By connecting your Node.js instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
