Menu
Send custom measurements
Faro Web SDK exposes some performance measurements, but there are cases where you might need to send application-specific data. For example, you might want to report some internals of the JavaScript framework you are using, or the time that it was elapsed before a user completed a form. The SDK comes with a simple API to do so.
Before you begin
- Ensure you have registered your app in the Application Observability plugin
- Initialize the Faro Web SDK as described in Get started with Grafana Faro Web SDK
Steps
Faro instance is an object that can be accessed, after initialization, by either importing it from the @grafana/faro-web-sdk
or by referencing it from the window
global object.
// Import the global faro instance
import { faro } from '@grafana/faro-web-sdk';
The faro.api
object is a wrapper of the Faro API and provides a pushMeasurement
method with which you can send any number of number values.
// Send custom measurements with Faro SDK.
// This example reports some hypothetical measurements from the JavaScript
// framework the application is using.
faro.api.pushMeasurement({
type: 'internal_framework_measurements',
values: {
root_render_ms: 142.3,
memory_used: 286,
