Menu
Grafana Cloud Data configuration Metrics Prometheus metrics config examples Monitor Flow with Prometheus and Grafana Cloud
The open source project Flow from Flow Blockchain provides a Prometheus exporter so that you can scrape metrics from your server at any one given point in time. To get scalable, long-term metrics storage, configure your Prometheus instance to push scraped samples to compatible remote storage endpoints such as Grafana Cloud’s serverless Mimir database using using remote_write. View the example below for how to configure remote_write in the prometheus.yml config file for Flow.
Prometheus Configuration for Flow
The prometheus.yml config file for Flow can be found at the following location:
https://github.com/onflow/flow-go/tree/master/module/metrics/example/prometheus.yml
Push metrics from Flow to Grafana Cloud using remote_write:
Below is an example remote_write code snippet you will need to add to your prometheus.yml config file in order to forward your metrics from your local Prometheus instance to remote storage with Grafana Cloud:
remote_write:
- url: <Your Metrics instance remote_write endpoint>
  basic_auth:
    username: <Your Metrics instance ID>
    password: <Your Grafana.com API Key>
You can find the https://...grafana.net/api/prom/push URL, username, and password for your metrics endpoint in the Cloud Portal. Click ‘Connections’ and select ‘Hosted Prometheus metrics’. The details display on the right. Need an account? Create a new Grafana Cloud account for free.
Learn more about the available remote_write configuration parameters from the Prometheus.io Configuration Docs.
Control the number of metric data points pushed to Grafana Cloud:
Every Grafana Cloud account includes 10,000 active series metric storage, free-forever.
Grafana Cloud provides additional 1 data point per minute (DPM) resolution for $8 per 1,000 series. You can adjust the total DPM you push to Grafana Cloud by adjusting the scrape_interval settings in your prometheus.yml config file. Learn more about how to adjust your Prometheus scrape interval.
