OracleDB integration for Grafana Cloud
OracleDB is an enterprise SQL Database system produced and marketed by Oracle Corporation. The OracleDB integration uses Grafana Alloy to collect metrics and alert logs for monitoring an OracleDB instance. Including metrics such as virtual memory usage, open file descriptors, sessions, processes, database wait times, and tablespace usage. It also includes monitoring the alert log of an OracleDB instance which contains valuable information for usage and operations of the instance.
This integration supports metrics provided by v0.0.1 of a third party OracleDB exporter, which is integrated into Alloy.
This integration includes 3 useful alerts and 1 pre-built dashboard to help monitor and visualize OracleDB metrics and logs.
Before you begin
In the Alloy configuration file, you must provide a connection string which has credentials with permissions to run queries.
To create a user with the SQL permissions required for the monitoring user “grafanau”.
-- Create the monitoring user "grafanau"
CREATE USER grafanau IDENTIFIED BY <YOUR-PASSWORD>;
-- Grant the "grafanau" user the required permissions
GRANT CONNECT TO grafanau;
GRANT SELECT ON SYS.GV_$RESOURCE_LIMIT to grafanau;
GRANT SELECT ON SYS.V_$SESSION to grafanau;
GRANT SELECT ON SYS.V_$WAITCLASSMETRIC to grafanau;
GRANT SELECT ON SYS.GV_$PROCESS to grafanau;
GRANT SELECT ON SYS.GV_$SYSSTAT to grafanau;
GRANT SELECT ON SYS.V_$DATAFILE to grafanau;
GRANT SELECT ON SYS.V_$ASM_DISKGROUP_STAT to grafanau;
GRANT SELECT ON SYS.V_$SYSTEM_WAIT_CLASS to grafanau;
GRANT SELECT ON SYS.DBA_TABLESPACE_USAGE_METRICS to grafanau;
GRANT SELECT ON SYS.DBA_TABLESPACES to grafanau;
GRANT SELECT ON SYS.GLOBAL_NAME to grafanau;
Install OracleDB integration for Grafana Cloud
- Find OracleDB and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send OracleDB metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your OracleDB setup.
Simple mode
Starting with Alloy v1.9.0
the Oracle Instant Client is a pre-requisite for Alloy to collect against Oracle Database. You may accomplish this by modifying your Alloy installation to properly configure the environment variable ORACLE_HOME
to be set for your installation, i.e. /lib/oracle/21/client64/lib
To modify your Alloy configuration please add the environment file for the service.
# The configuration file holding the Alloy config.
CONFIG_FILE="/etc/alloy/config.alloy"
# Link Oracle Libraries to alloy
ORACLE_HOME=<path/to/oracle/home>
These snippets are configured to scrape a single OracleDB instance running locally with default ports.
Integrations snippets
prometheus.exporter.oracledb "integrations_oracledb" {
connection_string = "oracle://user:password@localhost:1521/orcl.localnet"
discovery.relabel "integrations_oracledb" {
targets = prometheus.exporter.oracledb.integrations_oracledb.targets
rule {
target_label = "instance"
replacement = constants.hostname
rule {
target_label = "job"
replacement = "integrations/oracledb"
prometheus.scrape "integrations_oracledb" {
targets = discovery.relabel.integrations_oracledb.output
job_name = "integrations/oracledb"
scrape_interval = "5m0s"
scrape_timeout = "1m0s"
Logs snippets
linux
local.file_match "logs_integrations_integrations_oracledb" {
path_targets = [{
__address__ = "localhost",
__path__ = "/u01/base/diag/rdbms/*/*/trace/alert_*.log",
instance = constants.hostname,
job = "integrations/oracledb",
loki.process "logs_integrations_integrations_oracledb" {
forward_to = [loki.write.grafana_cloud_loki.receiver]
stage.multiline {
firstline = "\\d+-\\d+-\\d+T\\d+:\\d+:\\d+.\\d+-\\d+:\\d+"
max_lines = 0
max_wait_time = "3s"
loki.source.file "logs_integrations_integrations_oracledb" {
targets = local.file_match.logs_integrations_integrations_oracledb.targets
forward_to = [loki.process.logs_integrations_integrations_oracledb.receiver]
Advanced mode
To instruct Grafana Alloy to scrape your OracleDB instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
rule {
rule {
This integrations uses the prometheus.exporter.oracledb component to generate metrics from a OracleDB instance.
For the full array of configuration options, refer to the prometheus.exporter.oracledb component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each OracleDB instance to be monitored you must create a pair of these components.
component:
instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this OracleDB instance. Make sure this label value is the same for all telemetry data collected for this instance.
You can then scrape them by including each discovery.relabel
under targets
within the prometheus.scrape component.
Advanced logs snippets
linux
path_targets = [{
stage.multiline {
max_lines = 0
To monitor your OracleDB instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The OracleDB instance address__path__
: The path to the log file.instance
sets theinstance
loki.process defines how to process logs before sending it to Loki.
loki.source.file sends logs to Loki.
Kubernetes instructions
Before you begin with Kubernetes
Please note: These instructions assume the use of the Kubernetes Monitoring Helm chart
In the provided configuration snippet, you must provide a connection string which has credentials with permissions to run queries.
To create a user with the SQL permissions required for the monitoring user grafanau
Configuration snippets for Kubernetes Helm chart
To scrape your OracleDB instances, manually modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets <>
in the provided snippets with your desired configuration values.
Metrics snippets
alloy-metrics:
extraConfig: |-
connection_string = "oracle://<db_user>:<db_password>@<oracledb_service>.<oracledb_namespace>.svc.cluster.local:1521/<oracledb_db_name>"
forward_to = [prometheus.remote_write.grafana_cloud_metrics.receiver]
Logs snippets
In the agent configuration file, you must provide a connection string which has credentials with permissions to run queries.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send OracleDB metrics and logs to your Grafana Cloud instance.
Post-install configuration for the OracleDB integration
This integration supports metrics and logs from an OracleDB instance.
Enable the integration by adding the provided snippets to your agent configuration file.
If you want to show logs and metrics signals correlated in your dashboards, as a single pane of glass, ensure the following:
job
and instance
label values must match for metrics and logs scrape config in your agent configuration file.
job
label must be set to integrations/oracledb
(already configured in the snippets).
instance
label must be set to a value that uniquely identifies your OrableDB node. Please replace the default <your-instance-name>
value according to your environment - it should be set manually. Note that if you use localhost for multiple nodes, the dashboards will not be able to filter correctly by instance.
Below integrations
oracledb:
enabled: true
scrape_interval: 5m
scrape_timeout: 1m
scrape_integration: true
connection_string: 'oracle://user:password@localhost:1521/orcl.localnet' # replace with your connection string
max_idle_connections: 0
max_open_connections: 10
query_timeout: 5
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
- job_name: integrations/oracledb
static_configs:
- targets: [localhost]
labels:
instance: '<your-instance-name>'
job: integrations/oracledb
__path__: /u01/base/diag/rdbms/*/*/trace/alert_*.log # replace with your log path
pipeline_stages:
- multiline:
# match on timestamp. Format should be like '2023-01-20T09:38:23.454813-05:00'
# but feel free to modify to match your logs
firstline: '\d+-\d+-\d+T\d+:\d+:\d+.\d+-\d+:\d+'
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the OracleDB integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
Dashboards
The OracleDB integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- OracleDB overview
OracleDB overview dashboard
Alerts
The OracleDB integration includes the following useful alerts:
Metrics
The most important metrics provided by the OracleDB integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- oracledb_resource_current_utilization
- oracledb_resource_limit_value
- oracledb_tablespace_bytes
- oracledb_tablespace_free
- oracledb_tablespace_max_bytes
- oracledb_up
- oracledb_wait_time_application
- oracledb_wait_time_commit
- oracledb_wait_time_concurrency
- oracledb_wait_time_configuration
- oracledb_wait_time_network
- oracledb_wait_time_scheduler
- oracledb_wait_time_system_io
- oracledb_wait_time_user_io
- up
Changelog
# 1.0.0 - July 2025
* Updated instructions to accommodate for Alloy breaking change requiring configuration with an Oracle Client
# 0.0.4 - April 2024
* Added cluster selector to dashboards for kubernetes support
* Added default cluster label to agent config
* Bump version to 0.0.4
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - February 2023
* Initial release
Cost
By connecting your OracleDB instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
