Discourse integration for Grafana Cloud
Discourse is an application that is used to host a discussion platform. The Discourse integration uses Grafana Alloy to collect metrics from a Discourse instance like HTTP traffic, request rates, latency, sidekiq jobs, and browser heap usage.
This integration supports Discourse 2.8+
This integration includes 2 useful alerts and 2 pre-built dashboards to help monitor and visualize Discourse metrics.
Before you begin
This integration monitors a Discourse instance that is exposing Prometheus metrics via the official exporter plugin. Refer to the following official Discourse documentation for instructions on how to install plugins in Discourse.
In order for the plugin to work, add the plugin’s repository URL to the app.yml
file, which is usually present in /var/discourse/containers
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- sudo -E -u discourse git clone https://github.com/discourse/discourse-prometheus.git
Then rebuild the container:
cd /var/discourse
./launcher rebuild app
For more information on how to first install Discourse, please refer to their installation documentation.
The configuration of DISCOURSE_PROMETHEUS_TRUSTED_IP_ALLOWLIST_REGEX
may also need to be configured for Grafana Alloy to be trusted to scrape the metrics.
Install Discourse integration for Grafana Cloud
- Find Discourse and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Discourse metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Discourse setup.
Simple mode
These snippets are configured to scrape a single Discourse instance running locally with default ports.
Metrics snippets
discovery.relabel "metrics_integrations_integrations_discourse" {
targets = [{
__address__ = "localhost:80",
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "metrics_integrations_integrations_discourse" {
targets = discovery.relabel.metrics_integrations_integrations_discourse.output
job_name = "integrations/discourse"
Advanced mode
To instruct Grafana Alloy to scrape your Discourse instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
targets = [{
rule {
To monitor your Discourse instance, you must use a discovery.relabel component to discover your Discourse Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
component:
__address__
: The address to your Discourse Prometheus metrics endpoint.instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Discourse instance.
If you have multiple Discourse servers to scrape, configure one discovery.relabel
for each and scrape them by including each under targets
within the prometheus.scrape
component.
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
cd /var/discourse
may also need to be configured for the Grafana Agent to be trusted to scrape the metrics.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Discourse metrics to your Grafana Cloud instance.
Post-install configuration for the Discourse integration
After enabling the Prometheus plugin, you should configure Grafana Agent to scrape your Discourse nodes.
Discourse exposes a /metrics
endpoint. To scrape it, add the provided snippet to your agent configuration file.
Make sure to change targets in the snippet according to your environment.
- job_name: integrations/discourse
metrics_path: "/metrics"
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
static_configs:
- targets:
- localhost:80
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Discourse integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
Dashboards
The Discourse integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Discourse Jobs Processing
- Discourse Overview
Discourse Jobs Dashboard
Discourse Overview Dashboard 1
Discourse Overview Dashboard 2
Alerts
The Discourse integration includes the following useful alerts:
Metrics
The most important metrics provided by the Discourse integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- discourse_active_app_reqs
- discourse_http_duration_seconds
- discourse_http_requests
- discourse_page_views
- discourse_queued_app_reqs
- discourse_rss
- discourse_scheduled_job_count
- discourse_scheduled_job_duration_seconds
- discourse_sidekiq_job_count
- discourse_sidekiq_job_duration_seconds
- discourse_sidekiq_jobs_enqueued
- discourse_v8_used_heap_size
- up
Changelog
# 0.0.2 - September 2023
# 0.0.1 - December 2022
Initial Release
Cost
By connecting your Discourse instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
