Prometheus metrics config examples
Many open source projects provide Prometheus exporters so that you can scrape metrics from your application at any given point in time. Typically, the Prometheus metrics collector config file will specify how frequently to collect your metrics, known as the scrape_config
, plus the remote endpoint and authentication parameters for reliably storing the metrics, available under remote_write
. The Prometheus config file is customarily named prometheus.yml
To get scalable metrics storage that let you view your metrics over time, configure Prometheus to push scraped samples to compatible remote storage endpoints such as Grafana Cloud using using remote_write
. To view examples of how to use remote_write
, click one of the example open source projects below.
Open Source Projects with Prometheus Exporters
Search for your favorite open source projects below.
- AgnosticD
- Alerta
- Alibaba RSocket Broker
- Anchore Engine
- Antidote
- Antrea
- AnyCable Go
- Apache APISIX
- Apache DolphinScheduler
- Apache EventMesh
- Apache Ozone
- Apache ServiceComb Service-Center
- Apache ShardingSphere
- Apache ShenYu
- Aperture
- Apicurio Registry
- Aptos Core
- Artemis
- Automate
- Batch Shipyard
- Benchmark
- Benthos
- Berty
- Bitfrost
- Bivac
- BlockScout
- Boulder
- Monitor Breeze with Prometheus and Grafana Cloud
- BuildBuddy
- Monitor Cadence with Prometheus and Grafana Cloud
- Calico
- CBL-Mariner
- Cerbos
- CFRPKI
- Clair
- Cloudbreak
- Community Templates
- Concoure
- Conflux
- Contentlayer
- Convey
- Core Integrations
- CORTX
- CT Woodpecker
- CubeFS
- Curiefense
- Curve
- Darkroom
- Data Flow
- DataStation
- DeepOps
- DeepSea
- deSEC
- Dgraph
- Diem
- Dogbin
- DragonflyDB
- Eclipse Dataspace Connector
- eduMEET
- Elephant Shed
- Erigon
- Esplora
- Eval AI
- Evidently
- faasd
- Faucet
- Feature Form
- Flagger
- Fleet
- Flipt
- Flow Pipeline
- Flow
- Fluent Bit
- Fn
- Forest
- FreeBSD Ports
- Galaxy
- Monitor Gateway with Prometheus and Grafana Cloud
- Giskard
- GitRec
- GoAlert
- GoFlow2
- GoShimmer
- Gossamer
- Gravitee
- Harvest
- Heplify Server
- HStreamDB
- Hydra
- Monitor Hypertrace with Prometheus and Grafana Cloud
- IMGD
- Imixs Cloud
- Indexer
- IPFS Embed
- Jaeger
- Jam
- Jasmin
- Jepsen
- JHipster
- Jina
- Juno
- Monitor Kata Containers with Prometheus and Grafana Cloud
- Monitor Kayenta with Prometheus and Grafana Cloud
- Monitor Kolla with Prometheus and Grafana Cloud
- KQueen
- Krkn
- Monitor Lagon with Prometheus and Grafana Cloud
- Monitor Layotto with Prometheus and Grafana Cloud
- Libra
- Monitor Light-4J with Prometheus and Grafana Cloud
- Lighthouse Metrics
- Monitor Linux Microscope with Prometheus and Grafana Cloud
- Lndmon
- Lodestar
- LoopBack
- M3
- MagicOnion
- Magma
- Monitor Mainflux with Prometheus and Grafana Cloud
- Monitor MantaroBot with Prometheus and Grafana Cloud
- Materialize
- Mattermost Server
- Meta
- Micrometer
- MiNiFi
- Miso Lims
- MobileCoin
- Monitor Moira with Prometheus and Grafana Cloud
- MongoosePush
- MqPerf
- mtail
- Nats Surveyor
- NATS
- Nethermind
- Nimbus Eth2
- Nimbus
- Monitor NoSQLBench with Prometheus and Grafana Cloud
- OMD
- Omnia
- One App
- Open Whisk
- OpenCue
- Monitor OpenMU with Prometheus and Grafana Cloud
- OpenWrt Package
- Optimism
- Orb
- Outserv
- Parity Bridges Common
- Pbench
- PCM
- Penumbra
- Percona Operator
- PG Monitor
- Monitor Policy Server with Prometheus and Grafana Cloud
- Monitor Polywrap with Prometheus and Grafana Cloud
- Powergate
- Press
- Prisma Engines
- Promcat Resources
- Prometheus NATS Exporter
- Monitor Promscale with Prometheus and Grafana Cloud
- Proto Actor
- Quetz
- Quickwit
- Monitor Raphtory with Prometheus and Grafana Cloud
- Ray Autoscaler
- Reactive Interaction Gateway
- ReadySet
- Resoto
- Monitor Rest Server with Prometheus and Grafana Cloud
- Reverse Proxy
- Rewrite
- Robust Toolbox
- Rocket.Chat
- RSS Ant
- Monitor Saltbox with Prometheus and Grafana Cloud
- Scylla Monitoring
- Monitor SeaweedFS with Prometheus and Grafana Cloud
- Service Discovery
- Sloop
- SourceGraph
- Stackdriver Prometheus Sidecar
- Monitor Stacks Blockchain with Prometheus and Grafana Cloud
- Monitor Starcoin with Prometheus and Grafana Cloud
- Starlink Monitoring System
- Status Go
- Substrate
- Sui
- Swagger Stats
- Swarmlet
- Sync Gateway
- Syndesis
- Tailchat
- Teku
- Temporal
- Monitor Thingsboard with Prometheus and Grafana Cloud
- TiFlow
- Timesketch
- TiUP
- Toil
- Tracee
- Monitor Travis YML with Prometheus and Grafana Cloud
- Monitor Trickster with Prometheus and Grafana Cloud
- Trin
- Tuleap
- Monitor Turms with Prometheus and Grafana Cloud
- Monitor Uptrace with Prometheus and Grafana Cloud
- vFlow
- Monitor Vineyard v6d with Prometheus and Grafana Cloud
- Monitor Vitess with Prometheus and Grafana Cloud
- Warewulf
- Wasp
- Watchtower
- Monitor Watermill with Prometheus and Grafana Cloud
- Monitor Wazuh Kibana with Prometheus and Grafana Cloud
- Weaviate
- Wicked
- Monitor YDB with Prometheus and Grafana Cloud
- YMIR
- Monitor Yorkie with Prometheus and Grafana Cloud
- Monitor YugabyteDB with Prometheus and Grafana Cloud
- Zeebe
- Monitor Zentral with Prometheus and Grafana Cloud
- Monitor Zipkin with Prometheus and Grafana Cloud
- zkEVM Node
- Linux host using Prometheus and node_exporter
- Linux host
