MySQL integration for Grafana Cloud
MySQL is a managed, open source relational database that is a widely used for both small and large applications.
This integration includes 15 useful alerts and 2 pre-built dashboards to help monitor and visualize MySQL metrics and logs.
Before you begin
A running MySQL instance, user and password are required for the integration.
Supported versions:
- MySQL >= 5.6
- MariaDB >= 10.2
We recommend that you configure a separate user for Alloy, and give it only the strictly mandatory security privileges necessary for monitoring your node, as per the official documentation.
Install MySQL integration for Grafana Cloud
- Find MySQL and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send MySQL metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your MySQL setup.
Simple mode
These snippets are configured to scrape a single MySQL node with Grafana Alloy running locally.
Copy and Paste the following snippets into your Grafana Alloy configuration file.
Replace data_source_name
value to your MySQL DSN connection details. It must follow the URI patterns defined in go-sql-driver README, which is [username[:password]@][protocol[(address)]]/dbname[?param1=value1&...¶mN=valueN]
If your MySQL server requires authentication, check the integration documentation to understand how to setup a secret file.
Integrations snippets
prometheus.exporter.mysql "integrations_mysqld_exporter" {
data_source_name = "root:password@(localhost:3306)/"
discovery.relabel "integrations_mysqld_exporter" {
targets = prometheus.exporter.mysql.integrations_mysqld_exporter.targets
rule {
target_label = "job"
replacement = "integrations/mysql"
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "integrations_mysqld_exporter" {
targets = discovery.relabel.integrations_mysqld_exporter.output
job_name = "integrations/mysqld_exporter"
Logs snippets
darwin
linux
windows
Advanced mode
To instruct Grafana Alloy to scrape your MySQL server, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
local.file "mysql_secret" {
filename = "/var/lib/alloy/mysql-secret"
is_secret = true
data_source_name = local.file.mysql_secret.content
rule {
rule {
This integration uses the prometheus.exporter.mysql component to collect metrics from a MySQL instance.
For better security, your DSN containing authentication details will be stored in a file, and loaded by Grafana Alloy as a secret. The snippets are prepared to read from /var/lib/alloy/mysql-secret
You can create this file using the following command;
echo -n 'user:password@(hostname:3306)/' > /var/lib/alloy/mysql-secret
For the full array of options included within this exporter, please check the component documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings. For each MySQL instance to be monitored you must create a pair of these components.
The snippets set the instance
label to your Grafana Alloy server hostname using the constants.hostname
variable. If you are running Grafana Alloy outside of your MySQL server host, change the variable to a value that uniquely identifies it.
You can then scrape them by including each discovery.relabel
under targets
within the prometheus.scrape
component.
Advanced logs snippets
darwin
To collect your MySQL Server logs, you must use a local.file_match component to tag the file to be scraped, a loki.source.file component to prepare it for Loki ingestion and a loki.process component to process your logs with adequate labels and drop empty lines.
You can check the full array of options in each component documentation.
linux
windows
Supported versions:
- MySQL >= 5.6
- MariaDB >= 10.2
We recommend that you configure a separate user for the Agent, and give it only the strictly mandatory security privileges necessary for monitoring your node, as per the official documentation.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send MySQL metrics and logs to your Grafana Cloud instance.
Post-install configuration for the MySQL integration
This integration is configured to work with the mysqld_exporter
, which is embedded in Grafana Agent.
Enable the integration by manually adding the provided snippets to your agent configuration file.
This integration supports metrics and logs from MySQL. In order to see those signals correlated on your dashboard, as a single pane of glass, ensure the following:
job
andinstance
labels must match formysql_integration
(metrics) andlogs
in the Agent configuration file.job
label must be set tointegrations/mysql
(already configured in the snippets).instance
label must be set to a value that uniquely identifies your MySQL Node. Replace it manually, according to your environment. Note that if you uselocalhost
for multiple nodes, the dashboards will not be able to filter correctly by instance.
Please note that the value under data_source_name
snippet parameter must follow the URI patterns defined in go-sql-driver README, which is [username[:password]@][protocol[(address)]]/dbname[?param1=value1&...¶mN=valueN]
If you set the MYSQL_ALLOW_EMPTY_PASSWORD
flag on your MySQL Node configuration, you can omit the password in the URI.
For a full description of configuration options see how to configure the mysqld_exporter_config
block in the agent documentation.
Below integrations
mysqld_exporter:
enabled: true
instance: '<your-instance-name>' # must match instance used in logs
data_source_name: 'root:password@(localhost:3306)/' # replace with your connection string
relabel_configs:
- target_label: job
replacement: 'integrations/mysql' # must match job used in logs
- job_name: integrations/mysql
static_configs:
- labels:
instance: '<your-instance-name>' # must match instance used in mysqld_exporter
job: integrations/mysql # must match job used in mysqld_exporter
__path__: /var/log/mysql/*.log
pipeline_stages:
- regex:
expression: '(?P<timestamp>.+) (?P<thread>[\d]+) \[(?P<label>.+?)\]( \[(?P<err_code>.+?)\] \[(?P<subsystem>.+?)\])? (?P<msg>.+)'
- labels:
level: label
err_code:
subsystem:
- drop:
expression: "^ *$"
drop_counter_reason: "drop empty lines"
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the MySQL integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
Dashboards
The MySQL integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- MySQL
- MySQL logs
MySQL overview
MySQL logs
Alerts
The MySQL integration includes the following useful alerts:
Metrics
The most important metrics provided by the MySQL integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- instance:mysql_heartbeat_lag_seconds
- instance:mysql_slave_lag_seconds
- mysql_global_status_aborted_clients
- mysql_global_status_aborted_connects
- mysql_global_status_binlog_cache_disk_use
- mysql_global_status_binlog_cache_use
- mysql_global_status_binlog_stmt_cache_disk_use
- mysql_global_status_binlog_stmt_cache_use
- mysql_global_status_buffer_pool_pages
- mysql_global_status_bytes_received
- mysql_global_status_bytes_sent
- mysql_global_status_commands_total
- mysql_global_status_connections
- mysql_global_status_created_tmp_disk_tables
- mysql_global_status_created_tmp_files
- mysql_global_status_created_tmp_tables
- mysql_global_status_handlers_total
- mysql_global_status_innodb_buffer_pool_bytes_data
- mysql_global_status_innodb_data_read
- mysql_global_status_innodb_data_written
- mysql_global_status_innodb_log_waits
- mysql_global_status_innodb_mem_adaptive_hash
- mysql_global_status_innodb_mem_dictionary
- mysql_global_status_innodb_num_open_files
- mysql_global_status_innodb_page_size
- mysql_global_status_innodb_pages_written
- mysql_global_status_key_blocks_unused
- mysql_global_status_key_blocks_used
- mysql_global_status_max_used_connections
- mysql_global_status_open_files
- mysql_global_status_open_table_definitions
- mysql_global_status_open_tables
- mysql_global_status_opened_files
- mysql_global_status_opened_table_definitions
- mysql_global_status_opened_tables
- mysql_global_status_qcache_free_memory
- mysql_global_status_qcache_hits
- mysql_global_status_qcache_inserts
- mysql_global_status_qcache_lowmem_prunes
- mysql_global_status_qcache_not_cached
- mysql_global_status_qcache_queries_in_cache
- mysql_global_status_queries
- mysql_global_status_questions
- mysql_global_status_select_full_join
- mysql_global_status_select_full_range_join
- mysql_global_status_select_range
- mysql_global_status_select_range_check
- mysql_global_status_select_scan
- mysql_global_status_slow_queries
- mysql_global_status_sort_merge_passes
- mysql_global_status_sort_range
- mysql_global_status_sort_rows
- mysql_global_status_sort_scan
- mysql_global_status_table_locks_immediate
- mysql_global_status_table_locks_waited
- mysql_global_status_table_open_cache_hits
- mysql_global_status_table_open_cache_misses
- mysql_global_status_table_open_cache_overflows
- mysql_global_status_threads_cached
- mysql_global_status_threads_connected
- mysql_global_status_threads_created
- mysql_global_status_threads_running
- mysql_global_status_uptime
- mysql_global_status_wsrep_local_recv_queue
- mysql_global_status_wsrep_local_state
- mysql_global_status_wsrep_ready
- mysql_global_variables_innodb_additional_mem_pool_size
- mysql_global_variables_innodb_buffer_pool_size
- mysql_global_variables_innodb_log_buffer_size
- mysql_global_variables_key_buffer_size
- mysql_global_variables_max_connections
- mysql_global_variables_open_files_limit
- mysql_global_variables_query_cache_size
- mysql_global_variables_table_definition_cache
- mysql_global_variables_table_open_cache
- mysql_global_variables_thread_cache_size
- mysql_global_variables_tokudb_cache_size
- mysql_global_variables_wsrep_desync
- mysql_heartbeat_now_timestamp_seconds
- mysql_heartbeat_stored_timestamp_seconds
- mysql_info_schema_processlist_threads
- mysql_slave_status_seconds_behind_master
- mysql_slave_status_slave_io_running
- mysql_slave_status_slave_sql_running
- mysql_slave_status_sql_delay
- mysql_up
- up
Changelog
Cost
By connecting your MySQL instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
