Track navigation and resource performance
The Faro Web SDK Performance Instrumentation automatically instruments website navigation (page loading and rendering) and resources (JavaScript, CSS, images, and other files) to help you identify performance bottlenecks and make improvements.
Getting started
Performance Instrumentation is enabled by default, no further work needed.
Performance instrumentation explained
The Faro Web SDK uses browser APIs to retrieve detailed performance metrics and calculates, enriches, and sends custom metrics as faro.performance.navigation
and faro.performance.resource
events. Faro creates a unique ID per event, to map resources to navigation events and order navigation events in a session.
The PerformanceNavigationTiming (MDN Web Docs) interfaces provides metrics on loading and rendering a single full document, for example opening a page, reloading a page, or following a link to another page.
The PerformanceResourceTiming (MDN Web Docs) interface provides detailed network data for loading resources, for example loading JavaScript, CSS, images, or fonts.
Navigation event
The faro.performance.navigation
contains all metrics from faro.performance.resource
event and the following
metrics and properties:
Metrics
duration
: the full navigation time,loadEventEnd - startTime
pageLoadTime
: the time to load and render a page,domComplete - fetchStart
documentParsingTime
: the time the browser needs to parse the HTML document and to construct the Document Object Model (DOM),domInteractive - (domLoading - timeOrigin)
domProcessingTime
: the time to load and execute resources afterDOMContentLoaded
,domComplete - domInteractive
domContentLoadHandlerTime
: the time to execute delayed scripts after theload
event,loadEventEnd - loadEventStart
onLoadTime
: the time it takes to execute scripts which are delayed to be started after the load event,loadEventEnd - loadEventStart
ttfb
: the time from making the request to receiving the first byte from server,responseStart - activationStart
Properties
faroNavigationId
: unique ID for the navigationfaroPreviousNavigationId
: unique ID for the previous navigation, orunknown
type
: the navigation type,back_forward,navigate,prerender,reload
visibilityState
: the visibility of the page during the navigation
The visibilityState
property can be useful to remove noise and get accurate results when filtering out hidden navigation, because browsers prioritize visible/foreground work and tabs loaded in the background are usually slower.
Resource event
Note
The instrumentation only sends events initiated by calls to thefetch
method or initiated by a XMLHttpRequest.
The faro.performance.resource
event contains the following metrics and properties:
Metrics
duration
: the full resource load time,responseEnd - startTime
dnsLookupTime
the DNS lookup time,domainLookupEnd - domainLookupStart
tcpHandshakeTime
: the TCP handshake time,connectEnd - connectStart
tlsNegotiationTime
: the TLS negotiation time,requestStart - secureConnectionStart
redirectTime
: the time to follow all redirects,redirectEnd - redirectStart
requestTime
: the request time,responseStart - requestStart
responseTime
: the response time,responseEnd - responseStart
fetchTime
: the time to fetch a resource without redirects,responseEnd - fetchStart
serviceWorkerTime
: the ServiceWorker processing time,fetchStart - workerStart
Properties
name
: the resource URLinitiatorType
: the element, not media type, that triggered the resource downloadprotocol
: the network protocol used to fetch the resourcedecodedBodySize
: the size in octets of the message body after removing content encodingencodedBodySize
: the size in octets of the payload body before removing any applied content encodingscacheHitStatus
: the type of cache the resource was loaded from:cache
: direct cache hitconditionalFetch
: loaded via a 304fullLoad
: loaded from the server
renderBlockingStatus
: the render block status of a resource which has theblocking="render"
attribute:blocking
the resource potentially blocks renderingnon-blocking
the resource doesn’t block renderingunknown
: therenderBlockingStatus
property is not available in Firefox and Safari
responseStatus
: the HTTP response status code returned when fetching a resource. This property is not available in Firefox and Safari and is set tounknown
for those browsers.
Disable the performance instrumentation
You can disable the Performance Instrumentation by setting enablePerformanceInstrumentation
to false
in the settings object in the getWebInstrumentations function when initializing Faro.
Disabling the performance instrumentation is generally not recommended because:
- You lose insights into the rendering and resource load performance of your site
- It may impact other features in the Frontend Observability app
initializeFaro({
url: 'https://my-domain.my-tld/collect/{app-key}',
app: {
instrumentations: [
...getWebInstrumentations({
enablePerformanceInstrumentation: false,
Enable or disable tracking of all resource events
If you want to track all resources set trackResources
to true
in the Faro configuration (trackResources: true
If you do not want tracking any resources at all, set trackResources
to false
initializeFaro({
app: {
instrumentations: [
trackResources: true, // or false to turn off resource tracking
