Configure AWS Monitoring with Terraform
You can define as code AWS monitoring scrape jobs and accounts using Terraform.
![YouTube Video](https://img.youtube.com/vi/EVEQBtm-SvU/maxresdefault.jpg)
Before you begin, you must have the following installed:
- cURL
- jq
Grant Grafana Cloud Access to Your CloudWatch Data
This sections will help you use Terraform to configure an IAM role and access policy in your AWS Account, which will authorize Grafana Cloud to access your CloudWatch data.
Before you begin
Click Details in the Prometheus card of the Grafana Cloud Portal to find:
- The username / instance ID for your Grafana Cloud Prometheus. You can also find this information from the
grafana_cloud_stack
data source. - The Terraform snippet you need to provision the IAM role
Input variables
The input variables for the IAM role are:
external_id
: The username / instance ID for your Grafana Cloud Prometheus. AWS uses an external ID to provide an extra layer of security when giving Grafana access to pull your CloudWatch metrics into Grafana Cloud.iam_role_name
: A customizable name of the IAM role used by Grafana for the CloudWatch integration. The default value isGrafanaCloudWatchIntegration
Output variable
The output variable is role_arn
, which is the IAM role ARN you need to use when you create the scrape job.
Create a new AWS role
Create an AWS role so that Grafana can then assume a role that has access only to your CloudWatch data, with no need to share access and secret keys.
At the Create new scrape job configuration page, select Automatically to create a new role in the AWS IAM console.
Click Use Terraform.
Configure the AWS CLI.
Copy this snippet into your Terraform file.
Run the
terraform apply
command, and either set variables directly in the CLI or create atfvars
file as the following shows:To set the variables directly in the CLI, use the following example:
bash terraform apply -var="grafana_importer_external_id=<your external ID>" -var="iam_role_name=GrafanaCloudWatchIntegration"
To create a
tfvars
file (.tfvars), add the following text: grafana_importer_external_id="<your external ID>" iam_role_name="GrafanaCloudWatchIntegration"
Run the following command:
terraform apply -var-file="<your-tfvars-file>.tfvars"
After the Terraform apply command has finished creating the IAM Role, it outputs your role_arn. For example:
role_arn = "arn:aws:iam::<yourAWSAccountID>:role/<iam_role_name>"
Configure Grafana Cloud authentication
Configure authentication before using the Grafana Terraform provider.
Create a Grafana Cloud access policy
To create an access policy for your organization in the Grafana Cloud portal, refer to these steps.
Add scopes to the Grafana Cloud access policy
Add scopes to the access policy.
Enter a scope in the Add Scope textbox to search for a scope.
Assign the following required permissions (scopes):
integration-management:read
integration-management:write
stacks:read
Create a Grafana Cloud access policy token
In your Grafana Cloud stack, generate a token to authenticate the provider with the cloud provider API. Follow the on-screen instructions, or refer to the steps in Create one or more access policy tokens.
Obtain the regional Cloud Provider API endpoint
You need the URL for the cloud provider provider API to communicate.
Copy and use the following script to return a list of all the Grafana Cloud stacks you own, along with their respective cloud provider API hostnames.
curl -sH "Authorization: Bearer <Access Token from previous step>" "https://grafana.com/api/instances" | \ jq '[.items[]|{stackName: .slug, clusterName:.clusterSlug, cloudProviderAPIURL: "https://cloud-provider-api-\(.clusterSlug).grafana.net"}]'
Select the hostname for the stack you wish to manage. In the following example, the correct hostname for the herokublogpost stack is https://cloud-provider-api-prod-us-central-0.grafana.net.
[ { "stackName": "herokublogpost", "clusterName": "prod-us-central-0", "cloudProviderAPIURL": "https://cloud-provider-api-prod-us-central-0.grafana.net" } ]
Set up the Grafana Terraform Provider
Set up the Grafana Terraform provider with either of these methods:
- Terraform commands
- Environmental variables
Configure the Grafana Terraform Provider
Include the provider as a dependency in your Terraform configuration.
terraform { required_providers { grafana = { source = "grafana/grafana" version = ">= 3.13.1" # minimum required version that includes Cloud Provider support } } }
Configure AWS support for the Grafana Terraform provider with the following snippet, which uses the access token and cloud provider API URL obtained in the previous steps.
provider "grafana" { // ... cloud_provider_url = <Cloud Provider API URL from previous step> cloud_provider_access_token = <Access Token from previous step> }
Environment variables
When running Terraform commands, set the cloud provider URL and access token in an empty Grafana provider block with environment variables (GRAFANA_CLOUD_PROVIDER_ACCESS_TOKEN
and GRAFANA_CLOUD_PROVIDER_URL
provider "grafana" {}
You can define the following resources and data sources with the Grafana Terraform provider.
Resource descriptions
Example Terraform
The following snippets are for obtaining EC2 and RDS metrics. Replace the values with your values.
