A comprehensive Grafana data source plugin for StarTree Pinot, enabling real-time analytics and visualization of your StarTree Pinot cluster data with support for time series, logs, and annotations.
AI assistant for Grafana that helps teams troubleshoot issues, query telemetry, manage dashboards, and navigate Grafana in Cloud or connected self-managed deployments.
JSON API, CSV, TSV, XML, GraphQL, HTML, Google Sheets and HTTP/REST API datasource for Grafana. Do infinite things with Grafana. Transform data with UQL/GROQ. Visualize data from many apis including Amazon AWS, Microsoft Azure, Google Cloud / GCP and RSS/ATOM feeds directly. Also support visualizing logs and traces.
Dell PowerScale OneFS API datasource for Grafana. Query cluster statistics, node health, storage capacity, and performance metrics.
Define flowcharts and diagrams as code with Graphviz DOT, connect your metrics, and visualize them in your choice of layouts without manual drawing! Perfect for technical architectures, business processes, flowcharts, and organizational structures. Diagrams update automatically with live data.
Observability app for Microsoft Teams call quality, users, sites, and issue insights.
The GitHub data source plugin for Grafana lets you to query the GitHub API in Grafana so you can visualize your GitHub repositories and projects.
Box-and-whisker plots with Xf-Rf control limits, outlier detection, and Cp/Cpk capability analysis.
GoogleAnalytics Visualize & datasource
Seamless monitoring and analytics for your 3CX phone system
SVG Visualization Panel
Grafana datasource plugin for Akamai. Queries the Akamai SIEM Integration API for WAF/Bot/Client-Reputation security events and the Reporting API v2 for CDN traffic metrics using EdgeGrid HMAC-SHA-256 authentication.
Akvorado netflow data source using akvorado api
Shows list of alerts and their current status
Add external Alertmanagers (supports Prometheus and Mimir implementations) so you can use the Grafana Alerting UI to manage silences, contact points, and notification policies.
The most geeky clock panel ever for Grafana: build a watch-style clock from hand geometry and numerals to bezel scales, subdials, segmented gauges, and transparent mechanical movement.
Altinity Grafana datasource for ClickHouse
Use Amazon Athena with Grafana
Query and visualize AWS Aurora data with grafana
Open source time series database & alerting
Use Amazon Redshift in Grafana
Managed timeseries database from amazon
It's like Google Analytics, but for Grafana dashboards!
List annotations
Anodot Grafana Panel for usage together with anodot-datasource
Datasource for anodot-panel plugin
Apache Cassandra Datasource for Grafana
Apache IoTDB
AppDynamics datasource plugin for Grafana
An arc diagram panel plugin for Grafana.
AI-powered observability assistant with MCP integration. Query databases, analyze metrics, manage dashboards, and troubleshoot issues through natural language with 56+ integrated tools.
AstraDB datasource plugin for Grafana
An Astro UXDS theme for Grafana dashboards.
Data source for AWS Application Signals
AWS Datasource Provisioner
A managed service to collect, store, organize and monitor data from industrial equipment
Create end-user 3D digital twin applications to monitor industrial operations with AWS IoT TwinMaker. AWS IoT TwinMaker is a service that makes it faster and easier for developers to create digital replicas of real-world systems, helping more customers realize the potential of digital twins to optimize operations.
Query Axiom through Grafana
Monitor your Azure Cloud Native services
A data source for Azure Cosmos DB
Grafana data source for Azure Data Explorer
The Grafana data source plugin for Azure DevOps
Data source for Microsoft Azure Monitor & Application Insights
Categorical charts with group support
Horizontal and vertical gauges
Breadcrumb Panel for Grafana
Bubble chart panel
Bump Chart Panel Plugin
Displays events in a sleek calendar view, pulling from diverse data sources for seamless integration
Powerful visualizations powered by Apache ECharts.
Insert, update application data, and modify configuration
Simulates and manages data with JavaScript and LLM, offering flexible control
Streamlines navigation with external links, dashboards, and dropdowns.
Display Base64 encoded and URL media files
Visualize RSS/Atom feeds
Connect to Local and Remote Grafana instances
Simplifies data presentation with intuitive table layouts
Data-driven text with Markdown and Handlebars support
Enhances dashboards with movable, standalone filter panels for dynamic control.
Grafana button control panel
Shows a calendar heatmap panel similar to GitHub contribution graphs.
Graphical representation of price movements of a security, derivative, or currency.
Explicit element placement
Catchpoint data source plugin for Grafana
Causely App for Grafana provides real-time service health monitoring and insights. Track service dependencies, health status, and performance metrics in a unified dashboard.
Panel for CDF visualizations
Grafana data source plugin for Chaos Mesh (A Chaos Engineering Platform for Kubernetes)
Chartwerk panel with extended chart customization
Checkmk data source for Checkmk 2.2.0 or higher
Monitor Cisco ASA (Adaptive Security Appliance) firewalls via read-only show commands over the ASA HTTP(S) exec interface.
The Cisco ISE Data Source Plugin enables querying and visualization of Cisco Identity Services Engine (ISE) data in Grafana, including session observability, infrastructure health monitoring, certificate lifecycle, network policy auditing, and security posture.
The Cisco Meraki DataSource Plugin is a Grafana backend datasource plugin that enables on-demand querying and visualization of Cisco Meraki device metrics, network performance data, and event logs through interactive dashboards.
Query Citrix DaaS (Citrix Cloud) session, application, and infrastructure data — Monitor OData analytics and Broker REST live state.
Team usage analytics for Claude Code powered by OpenTelemetry
ClickHouse datasource plugin for Grafana
Clock panel for grafana
Grafana datasource plugin for Cloudflare
Data source for Amazon AWS monitoring service
Data source for Amazon AWS CloudWatch Alarm status
A grafana data source plugin for CnosDB.
A data source for CockroachDB
Cognite Data Fusion datasource
A panel that displays values as colored svg images
Grafana Compact Hostmap Panel Plugin
Grafana plugin built as a datasource plugin that combines and contrasts different time shifts data.
A dynamic compass panel for Grafana
Convertify is a Grafana panel plugin for visualizing time-series data in binary or hexadecimal format, with support for bitfield-based analysis and column filtering. Perfect for monitoring and analyzing data from industrial systems, IoT devices, or control systems.
Grafana plugin allowing to download pcap files, collect packet analytics for specified data ranges from cPacket devices, and to import a list of dashboards for network observability.
Cribl Search
A data source for loading CSV data
Connect Grafana to Cube for semantic layer analytics. Query measures and dimensions, apply filters, and visualize your data.
A panel to display cubism like graph in grafana
D3-based Gauge panel for Grafana
List of dynamic links to other dashboards
Databricks datasource plugin for Grafana
Datadog datasource plugin for Grafana. Grafana Data dog datasource plugin
Scalyr Observability Platform
A table panel built on top of datatables.net
DBeast Monitor is a Grafana plugin for monitoring, troubleshooting, and optimizing the Elastic Stack.
Debug Panel for Grafana
Data source to retrieve Post Game Carnage Reports from Destiny 2
Display diagrams and charts with colored metric indicators
CESNET DP³ plugin for Grafana
A data source for drone
Connects Grafana to Druid
Concatenate a metric to an URL in order to display an image
DynamoDB datasource plugin for Grafana
Dynatrace datasource plugin for Grafana
Open source logging & analytics database
Mobile and web observability and data platform that empowers teams to deliver optimal user experiences
Enter the URL of the image you want, and add some metrics on it.
ESnet Chord Panel Plugin for Grafana 8.3 and newer
Matrix Panel Plugin that allows comparison of two non-timeseries categories
A datasource plugin for Factry Historian. Requires Factry Historian v7.3.0 or later.
Falcon LogScale data source for Grafana
This is a grafana data source that uses ieee1888(a.k.a FIAP)
Finnhub Data Source
Google firestore datasource plugin for grafana
Svg flowchart visualization
Consume webhook payloads, map and route them into your Grafana Logs panel.
Flow charting visualization
FortiGate datasource for Grafana. Query and visualize security logs including traffic, UTM (antivirus, webfilter), and event logs from FortiGate devices through the REST API.
Query Foxglove telemetry data from Grafana dashboards.
A data source plugin for loading data from OGC SensorThings APIs into Grafana.
Visualize how data moves through a process
Tasks and processes over time
Standard gauge visualization
Load GCP incident logs from the status page
Geomap panel
Display data on top of a OGC WMS 1.3.0 base map layer
GitLab datasource plugin for Grafana
GizmoSQL data source plugin - connect to GizmoSQL via Arrow Flight SQL
Google BigQuery datasource for Grafana
A Grafana data source plugin for querying and visualizing logs from Google Cloud Logging.
Data source for Google's monitoring service (formerly named Stackdriver)
A Grafana data source plugin for querying and visualizing traces from Google Cloud Trace.
The Google Sheets data source plugin for Grafana lets you to visualize your Google spreadsheets in Grafana
Manage Grafana Enterprise Logs (GEL) - a commercial offering for highly-scalable, simple and reliable logs clusters based on Loki (OSS).
Manage Grafana Enterprise Metrics (GEM) - a commercial offering for highly-scalable, simple and reliable traces clusters based on Mimir (OSS).
Manage Grafana Enterprise Traces (GET) - a commercial offering for highly-scalable, simple and reliable traces clusters based on Tempo (OSS).
Visualize log volumes to easily detect anomalies or significant changes over time, without needing to compose LogQL queries.
Quickly find related metrics with a few clicks, without needing to write PromQL queries to retrieve metrics.
View and analyze high-level service performance, identify problem processes for optimization, and diagnose issues to determine root causes.
Data source for Grafana Pyroscope, horizontally-scalable, highly-available, multi-tenant continuous profiling aggregation system.
Use Rate, Errors, and Duration (RED) metrics derived from traces to investigate errors within complex distributed systems.
A comprehensive Grafana plugin to connect to Yamcs servers for real-time telemetry visualization and commanding capabilities. Designed for mission control centers, aerospace applications and beyond.
Render Mermaid.js diagrams in Grafana with live data from queries, dashboard variables, and threshold-based styling
The old default graph panel
Groonga datasource
Plugin to import HackerOne information into Grafana.
Data source plugin for Harper
A Grafana data source for Haystack tagged data
Like a histogram over time
Display metrics for your Hetzner Cloud Servers and Load Balancers.
Distribution of values presented as a bar chart.
Honeycomb datasource plugin for Grafana
Visualize your resources in a compact table with powerful tooltips and grouping
Heatmap for the hours of the day
A high density view of large amounts of data focused on high performance computing
Grafana panel for displaying metric sensitive HTML and SVG graphics
Hydrolix data source for Grafana
Connect to IBM Db2 databases and query your data using SQL.
Grafana plugin for IBM Z OMEGAMON
save image to grafana
Displays air quality information on a floor plan.
Visualize image files for indoor maps.
Data source for InfluxDB, an open source time series database
Grafana datasource plugin for Instana: Automatic Infrastructure and Application Monitoring
Get help exactly when and where you need it. Interactive learning brings contextual documentation and interactive guides directly into Grafana, so you can learn and build without leaving your workflow.
View data, from a table data source, as a interactive tree like structure
Data source for ITRS Analytics platform
A comprehensive observability platform for distributed tracing, service map visualization, log analysis, exception tracking, and AI-powered insights.
Open source, end-to-end distributed tracing
Jenkins datasource plugin for Grafana
Jira datasource plugin for Grafana
Load JSON data over your arbitrary HTTP backend
A data source plugin for loading JSON APIs into Grafana.
Kafka Datasource Plugin
AquaQ Analytics' backend adaptor for KX Systems' kdb+ database
Visualize and explore Kentik network observability data in Grafana.
This plugin has been replaced by the Kentik Connect Datasource (kentik-connect-datasource). It is kept as a bridge to auto-install the new datasource for existing users. Please configure and use kentik-connect-datasource directly.
Connect Grafana to Kinetica for real-time analytics on large-scale data. Supports visual query builder, raw SQL, time series, and Grafana alerting.
Choropleth map panel using Leaflet and chroma-js for Grafana
Plugin to easily allow LLM based extensions to grafana
Grafana datasource plugin for LogicMonitor
Like Prometheus but for logs. OSS logging solution from Grafana Labs
Looker datasource plugin for Grafana
Luciq's plugin brings your mobile app's performance and stability insights straight to Grafana.
Node Graph and Network Geomap
A plugin for Grafana that visualizes GPS points on a 3D globe
Materialize datasource for Grafana
Panel for tracking via Matomo
Aliyun MaxCompute as a (Backend) Datasource
Data source for Microsoft SQL Server compatible databases
Grafana mock datasource
Grafana plugin for MonetDB
MongoDB datasource plugin for Grafana
Moogsoft AIOps App
Mosaic Plot Panel
MQTT Client Datasource Plugin
MUX video streaming metrics datasource
Data source for MySQL databases
Allows Neo4j to be used as a DataSource for Grafana
The NetApp ONTAP DataSource Plugin is a Grafana backend datasource plugin that enables on-demand querying and visualization of storage metrics and operational data from NetApp ONTAP systems using the ONTAP REST API.
netdata datasource plugin
Topology map of a network. Graphs network traffic between nodes
Next-generation, actively maintained network weathermap by Tamir Suliman. A continuation and fork of the deprecated Network Weathermap plugin, updated for modern Grafana.
New Relic datasource plugin for Grafana
A datasource that provides data for nodegraph panel via api
Nominal datasource plugin for Grafana - connect to Nominal's time-series platform for monitoring and visualization
OData data source for Grafana
Display moving counter for countdown countup
openGemini grafana datasource plugin
Datasource plugin for openHistorian
Create flexible dashboards using data from OpenNMS® Horizon™ and/or OpenNMS® Meridian™.
Query OpenSearch to visualize logs or metrics.
Wind parameter visualization panel
Open-source SevOne plugin developed by Optimiz
Oracle Cloud Infrastructure Logs Data Source for Grafana
Oracle Cloud Infrastructure Metrics Data Source for Grafana
Oracle datasource plugin for Grafana
Orchestra Cities Map
Organisations Panel for Grafana
Switch Grafana organizations via dropdown menu or buttons.
Datasource plugin for OSIsoft PI Web API
PagerDuty data source plugin for Grafana
Palindrome.js Grafana panel
Pareto Chart for Grafana
Query and visualize Apache Parquet files stored in Amazon S3 or S3-compatible storage (MinIO, Wasabi, DigitalOcean Spaces). Leverage the columnar Parquet format for efficient data lake analytics directly in Grafana using a built-in lightweight SQL engine (SELECT, WHERE, GROUP BY, ORDER BY, LIMIT, and common aggregates).
Parseable is an open source, Kubernetes native, log storage and observability platform. This plugin allows you to visualize your Parseable logs in Grafana.
Percent change with trend display
Plot rotating machine operation point on a performance curve.
Performance Co-Pilot Grafana Plugin
A Grafana panel plugin to render interactive flowchart visualization of directed graph data.
Pixie's Grafana Datasource Plugin
Render charts with Plotly.js
Render chart from any datasource with Plotly javascript library
pnp4nagios datasource
Polystat panel for Grafana
Data source for PostgreSQL and compatible databases
Grafana datasource for Prometheus AlertManager
The Proofpoint TAP DataSource Plugin is a Grafana backend datasource plugin that enables on-demand querying and visualization of Proofpoint Targeted Attack Protection (TAP) SIEM events inside Grafana panels.
View air conditions on a psychrometric chart.
See the relationship between pump flow rate and pressure at different operating conditions
JSON and ANSI styled logs viewer
Render a QR code
QuestDB datasource plugin for Grafana
Quickwit is an OSS, Cloud-Native search engine on object storage. This plugin allows you to visualize logs, traces, and build dashboards on top of Quickwit.
Rabbitmq streaming datasource plugin
Interactive vinyl-style radio panel for Grafana with day-based station scheduling and optional timed override. Supports per-station now playing metadata and playlist-friendly continuous playback.
A dynamic range slider panel for Grafana that allows users to select a value range for filtering data.
Allows to connect to any Redis database On-Premises and in the Cloud.
Provides Application pages and custom panels for Redis Data Source.
Allows connecting to Redis Enterprise software clusters using REST API.
Subscribe to riemann.io websocket streams!
Grafana datasource plugin for rqlite
Salesforce datasource plugin for Grafana
Sankey Panel Plugin for Grafana
The Grafana® data source plugin for SAP HANA®. SAP HANA® is the trademark or registered trademark of SAP SE or its affiliates in Germany and in several other countries.
3D satellite visualization panel.
SCADA-like synoptic panel for grafana
A really easy-to-use scatter-plot plugin panel for table formatted Grafana data
Grafana datasource plugin for Sentry
Service Dependency Graph panel for Grafana. Shows metric-based, dynamic dependency graph between services, indicates responsetime, load and error rate statistic for individual services and communication edges. Shows communication to external services, such as Web calls, database calls, message queues, LDAP calls, etc. Provides a details dialog for each selected service that shows statistics about incoming and outgoing traffic.
ServiceNow datasource plugin for Grafana
The shift selector allows you to adjust the time range of your grafana dashboard to one specific shift or a range of shifts.
Sierra Plot Panel
Sift Grafana Datasource
Signal K datasource for streaming realtime data over WebSocket and querying historical data via History API. The plugin is designed to work with the Signal K server and signalk-to-influxdb2 plugin.
simple grpc datasource plugin
Connect to OPC-UA servers to read industrial data. Supports anonymous, username/password, and certificate authentication.
Apache SkyWalking
Slope Graph Panel
A Grafana panel plugin that visualizes time-series data and provides trend, stats, and anomaly insights.
Snowflake datasource plugin for Grafana
A panel plugin designed to visualize the production flow of solar panels within the Grafana monitoring platform.
Grafana datasource plugin for SolarWinds
Data source for SPARQL endpoints
Bullet chart, progress bar, and bar gauge with optional SPC mode.
Perform statistical analysis on 3D CAD model features.
Connect your measurement database for SPC calculations, quality metrics, and trend forecasting.
Create common SPC charts like Xbar-R, XbarS, and XmR charts.
Professional SPC charts with run rules, attribute charts, and advanced control limits. Commercial plugin by Kenso Software.
Histogram panel with SPC control limits, bell curves, and capability indices.
Pareto chart with cumulative percentage line, threshold highlighting, and statistics table.
A retro-style Split Flap display panel for Grafana. Perfect for visualizing counters, metrics, and status codes with a classic airport terminal aesthetic.
Splunk datasource plugin for Grafana
Splunk Infrastructure Monitoring (formerly SignalFx) datasource plugin for Grafana. Also known as Splunk Observability
SQLite as a (Backend) Datasource
Grafana Sqlyze Data Source. Generic datasource plugin to connect SQL databases via ODBC driver
Big stat values & sparklines
Status Overview Panel for Grafana
Status Panel for Grafana
A simple panel to show resource status
Strava datasource
Streamr data source plugin for Grafana
Sumo Logic datasource plugin for Grafana
Calculates position of Sun and Moon.
Grafana Datasource Plugin for SurrealDB
Worldwide black box monitoring for services and applications
Supports many column styles
Advanced table panel with support for multi-level column headers and flexible column grouping. Features include hierarchical header organization, customizable vertical and horizontal grouping, sorting, filtering, and column resizing capabilities.
Tableau Server / Cloud datasource for Grafana. Query workbooks, views, data sources, users, groups, jobs, and extract tasks via the Tableau REST API.
Animated spinner panel with rotation speed based on metric values. Perfect for visualizing real-time metrics with dynamic animation.
High volume, minimal dependency trace storage. OSS tracing solution from Grafana Labs.
Generates test data in different forms
Supports markdown and html content
thruk datasource
Time based line, area and bar charts
Datasource-configured buttons panel plugin which set the time range of your Grafana dashboard
Tokio Console datasource for Grafana
Comprehensive ClickHouse monitoring with 3D visualizations, merge tracking, query analysis, and time travel
A panel that visualizes GPS points as a line on an interactive map
React based traffic light panel for Grafana
Tree View for JSON API datasource. It can show JSON REST API responses, for example: Kubernetes API
Area-based visualization of hierarchical data
Trend Panel
The Trino datasource allows to query and visualize Trino data from within Grafana.
Grafana panel for displaying time series data as function of distance
Create panels from Vega[-Lite] specs.
Data source for Vertica and compatible databases
VictoriaLogs datasource plugin for Grafana
VictoriaMetrics datasource plugin for Grafana
Display video from a URL, YouTube ID, or an iFrame.
Grafana backend datasource plugin for VMware vSphere (vCenter Server). Query and visualize virtual machine, host, datastore, cluster, infrastructure, event, alarm, and vSAN metrics from vCenter using the govmomi vSphere API.
A waterfall panel for a single time-series
Wavefront datasource plugin for Grafana
Connect Grafana to Wazuh (SIEM/XDR) — query alerts, vulnerabilities, FIM events, SCA compliance scores, and agent status without manual OpenSearch configuration.
A panel to display website navigation.
A data source plugin for handling WebSocket connections on Grafana. Works great in the general use case or with IoT projects built on Golioth.
Grafana data source to interpret GraphQL query results as timeseries data
WordCloud / TagCloud Panel
Supports arbitrary X vs Y in a graph to visualize the relationship between two variables.
XYZ chart
YDB datasource plugin for Grafana
Yugabyte datasource plugin for grafana
Zabbix plugin for Grafana
A datasource plugin to add Zendesk integration
Query and visualize traces from Zipkin, an open-source distributed tracing system.
Query Zoom meeting quality, room health, user activity and phone device status from Grafana.
Query Zscaler Internet Access (ZIA) security posture data — firewall rules, SSL inspection, DLP, URL filtering, locations, users, NSS servers, and sandbox quota.
Query Zscaler Private Access (ZPA) infrastructure health and security policy data — app connectors, service edges, cloud connector groups, access policy rules, application segments, server groups, and connector groups.
