A log viewer panel for Grafana with JSON and ANSI styling support.
- Full styling and link support for ANSI messages
- Syntax highlighting and collapsible nesting for JSON messages
- Match log styling of your favorite terminal emulator or IDE with 300+ built-in color themes from Gogh, plus custom Grafana light/dark themes
- Easily navigate with a timeline chart of log records
- Virtual scrolling for handling large log volumes
Usage
Panel Layout
Settings: At the top of the panel is a header bar with various toggles and settings. On the left you'll see settings like theme, font size, or word-wrap.
Timeline: Next to settings is a toggle for the timeline chart. When shown, you'll see a bar chart with log records by time. Scroll to zoom, drag to pan. You can click a point on the timeline to find and scroll to the nearest record. You'll see other clickable elements like buttons to center the view, extend the view, or sync the dashboard's range. Vertical indicators show you your current selection, view, and dashboard range.
Search: Next to the timeline toggle is a search bar. Toggle this to enable/disable filtering. For ANSI log records, it searches by substring, optionally case sensitive or a regular expression. For JSON log records, you define a JavaScript lambda expression for filtering.
View: In the center you can toggle between viewing ANSI vs JSON logs. JSON logs are autodetected from records that look like JSON objects: a message enclosed in {} characters. When toggling between them, it will try to find a matching record based on keywords and sync the current scroll position. If a selected row is currently in view, it centers on a matching record instead.
Actions: On the right are actions like viewing record labels or copying.
Data Source
This panel works with any data source that returns log-like data. You can include multiple series. Each series should have these fields:
- Time: Prefers a field named
time, orts. Otherwise it picks the first time field. Otherwise it looks for the first UNIX timestamp-like field. - Message: Prefers a field named
message,msg,log,line,content, ortext. If not found, it picks the first string field. Otherwise it uses the field immediately after the time field. - Labels (optional): Prefers a JSON encoded string field named
labels,tags,metadata, orfields.
Contributing
See CONTRIBUTING.md for development setup and guidelines.
License
LGPL-3.0 - see LICENSE for details.
- ...and more
Insights
- Adoption
Running on 158 active Grafana instances.
- Activity
Last updated 14 May 2026.
2 releases in the past year.
- Version
- 1.1.1
- Dependencies
- Grafana >=11.6.11 <12 || >=12.0.10 <12.1 || >=12.1.7 <12.2 || >=12.2.5
- Developer
- nyrix
- ...and more
