Plugins
PanelCommunity
Leaflet Choropleth logo
Leaflet Choropleth
teosibileau
Get plugin
Grafana Leaflet Choropleth Panel
Cross-reference time-series metric data with GeoJSON to display colored polygons on a Leaflet map. A choropleth map shades regions proportionally to a statistical variable, making it easy to visualize how a measurement varies across geographic areas.
Choropleth panel screenshot
Requirements
  • Grafana >= 10.0.0
  • Node.js >= 22 (see .nvmrc)
  • pnpm (declared in package.json packageManager field)
  • Docker & Docker Compose (for the local dev environment)
Getting started
Terminal 1 — start the webpack dev build in watch mode:
pnpm install
pnpm run dev
Terminal 2 — start the Docker Compose environment:
docker compose up --build
# or: pnpm run server
Then open http://localhost:3000 in your browser. A provisioned dashboard is loaded automatically.
Note: An Ahoy configuration (.ahoy.yml) is included as an optional convenience wrapper around these commands.
Development environment
docker compose up starts two services:
  • Grafana (port 3000) — runs the plugin from the dist/ directory. Anonymous admin access is enabled so no login is required. A livereload script is injected into the Grafana HTML (see .docker/grafana/Dockerfile) so webpack rebuilds trigger automatic browser refresh.
  • InfluxDB 1.8 (port 8086) — pre-seeded with one year of hourly data via init scripts in .docker/influxdb/.
A provisioned datasource and dashboard are auto-loaded from .docker/grafana/provisioning/ on startup.
Configuration
These panel options are defined in src/module.ts:
Option Description Default
GeoJSON Data Fetch & store GeoJSON for the choropleth layer —
Hot Color Color for maximum values #ff0000
Cold Color Color for minimum values #0000ff
GeoJSON Key Feature property used to match metric series —
Auto Fit Bounds Fit map to visible features on data refresh true
Stroke Color Border color of polygons #ffffff
Stroke Width Border width of polygons (0–10) 1
Fill Opacity Opacity of polygon fill (0–1) 0.5
How it works
The plugin matches Grafana metric series to GeoJSON features using a tag-based naming convention and colors polygons with a chroma-js quantile scale on a Leaflet map with CartoDB dark tiles.
Example: given a series named metric{departamento=CONESA} and GeoJSON Key set to departamento, the plugin finds the GeoJSON feature whose departamento property equals CONESA and assigns it a color. The color is interpolated between the Cold Color (minimum value) and the Hot Color (maximum value) using a chroma-js quantile scale across all matched features.
Available scripts
Command Description
pnpm run dev Webpack watch mode (development)
pnpm run build Production build
pnpm run server Start Docker Compose environment
pnpm run test Jest in watch mode (changed files only)
pnpm run test:ci Jest single run (CI)
pnpm run typecheck TypeScript type-check (tsc --noEmit)
pnpm run lint ESLint
pnpm run lint:fix ESLint auto-fix + Prettier
Testing
Tests use Jest and React Testing Library.
pnpm run test      # watch mode — re-runs on changes
pnpm run test:ci   # single run (used in CI)
CI
GitHub Actions (.github/workflows/ci.yml) runs on every push and PR to master:
  1. build — lint, typecheck, and production build (uploads dist/ as artifact)
  2. test — runs pnpm run test:ci
  3. plugin-check — loads the built plugin into a Grafana container and verifies it is registered via the Grafana API
Project structure
src/
  module.ts              — plugin entry point & panel option definitions
  types.ts               — ChoroplethOptions interface
  components/
    ChoroplethPanel.tsx  — main React panel component + data matching
    ChoroplethMap.ts     — Leaflet map rendering + chroma-js color scale
    GeoJsonEditor.tsx    — panel editor: fetch / preview / clear GeoJSON
    GeoJsonKeyEditor.tsx — panel editor: select feature property key
Insights
  • Adoption
    Running on 133 active Grafana instances.
  • Activity
    Last updated 17 Apr 2026.
    1 release in the past year.
Version
1.0.0
Dependencies
  • Grafana >=11.5.0
Developer
teosibileau
  • 150+ data source integrations
  • Grafana Assistant - AI that correlates your data, builds queries, and answers questions
  • 10k Prometheus metrics + 50 GB logs, traces, and profiles on the free tier
  • ...and more
Create free account
