Alpine Clock Panel
Alpine Clock Panel is a configurable analog clock plugin for Grafana with watch-inspired styling, timezone support, metric-driven complications, and rich visual customization.
Highlights
- Configurable dial shapes, gradients, bezels, tick marks, numerals, and hand styles
- Timezone-aware rendering with optional dashboard time synchronization
- Stop-to-go second hand, animated bounce, and dynamic hand shadows
- Date/day windows, rolling date strip, four subdials, and a global metric hand
- Showcase dashboard with multiple design presets and TestData scenarios
Requirements
- Grafana 12.3.0 or newer
- Node.js version from the repository
.nvmrcfor local development
Getting started
- Install dependencies with
npm install. - Start development mode with
npm run dev. - Start Grafana locally with
npm run server. - Open
http://localhost:3000and add the Alpine Clock Panel to a dashboard.
Documentation
- Repository and full setup guide: https://github.com/dzaczek/grafana-alpine-clock-panel
- Full configuration reference: https://github.com/dzaczek/grafana-alpine-clock-panel/blob/main/docs/CONFIGURATION.md
- Local showcase dashboard:
provisioning/dashboards/showcase.json
Contributing
Issues and pull requests are welcome in the GitHub repository: https://github.com/dzaczek/grafana-alpine-clock-panel
- ...and more
Insights
- Adoption
Running on 718 active Grafana instances.
- Activity
Last updated 3 Jun 2026.
2 releases in the past year.
- Version
- 1.5.4
- Dependencies
- Grafana >=12.3.0
- Developer
- dzaczek
- ...and more
