Host Overview Panel
A Grafana panel plugin for visualizing the status of fleets of resources — servers, database instances, containers, or any entity with a status field and optional metrics.
Features
- Modern design for Grafana 12 — panel uses built-in theme-ready components.
- Flexible grouping — nest resources by any combination of fields, with configurable sort order, coloring, and layout.
- Multiple display modes — simple colored cells, cells with text labels, or rich table cards showing multiple fields per resource.
- Joins — attach metrics from other data frames to groups or individual resources via key-based joins.
- Field visualizations — text, colored text, colored background, gauges, and sparklines for joined or inline fields.
- Color overrides — fields and joins can override cell colors based on threshold severity.
- Data links support — define data links for any group, resource, or metric.
- Tooltips — hoverable tooltips with configurable title, fields, and joined data.
Requirements
- Grafana 12.0 or later.
Documentation
For setup guides, tutorials, and a full options reference, see the documentation site.
- ...and more
Insights
- Adoption
Running on 1,307 active Grafana instances.
- Activity
Last updated 10 Jun 2026.
2 releases in the past year.
- Version
- 1.2.0
- Dependencies
- Grafana >=12.0.10
- Developer
- taminomara
- ...and more
