Plugins
PanelCommunity
Grafmaid logo
Grafmaid
neildengg
Get plugin
Grafmaid Logo
Grafmaid
Grafana + Mermaid.js = Grafmaid
A Grafana panel plugin that renders Mermaid.js diagrams with live data from queries, dashboard variables, and threshold-based styling — turning static architecture diagrams into dynamic, data-driven visuals.
License GitHub release
Screenshots
Flowchart, Sequence, State diagrams
Dashboard Variables integration
Data Queries with threshold coloring
Features
  • All Mermaid diagram types — Flowchart, Sequence, Class, State, ER, Gantt, Pie, Mindmap, Timeline, Git Graph, C4, and more
  • Dashboard Variables — Use $variable / ${variable} syntax and {{#each var}} multi-value expansion
  • Data Queries — Inject live metric values via ${__data.CPU_A:display} shorthand or ${__data.fields.X} full syntax
  • Labels — Access metric labels with ${__data.CPU_A.labels.http_status}
  • Field Config — Standard Options support: Units, Thresholds, Value Mappings, Color scheme, Decimals
  • Threshold coloring — Color diagram nodes dynamically based on threshold values using ${__data.CPU_A:color}
  • Special character escaping — Auto-escape [ ] { } | > < in variable values to prevent syntax errors
  • Theme-aware — Auto-switches Mermaid theme based on Grafana dark/light mode
  • Responsive — SVG diagrams auto-scale with panel dimensions
Requirements
  • Grafana >= 12.3.0
Getting Started
  1. Install the plugin from the Grafana plugin catalog
  2. Add a new panel and select Grafmaid as the visualization
  3. Write your Mermaid diagram in the Mermaid Content option
  4. (Optional) Configure data source queries to inject live values
Configuration
Panel Options
Option Default Description
Mermaid Content Example flowchart Mermaid diagram definition with variable/data syntax
Escape special characters true Auto-escape Mermaid special characters in values
Max data rows 100 Max rows for {{#each data}} expansion (0 = unlimited)
Standard Options
The panel supports Grafana Standard Options via Field Config:
  • Unit — Format numeric values (percent, bytes, etc.)
  • Thresholds — Define color breakpoints (default: green base, red at 80)
  • Value Mappings — Map values to custom text
  • Color scheme — Defaults to "From thresholds (by value)"
  • Decimals — Control decimal precision
Data Syntax Quick Reference
Syntax Description
$variable Dashboard variable substitution
{{#each var}}...{{value}}...{{/each}} Multi-value variable expansion
${__data.CPU_A:display} Formatted value from query (auto value field)
${__data.CPU_A:color} Threshold color from query
${__data.CPU_A.labels.server} Metric label value
${__data.fields.Value} Explicit field access from series[0]
{{#each data.CPU_A}}...{{/each}} Iterate over query rows
Example: Threshold-colored Diagram
graph LR
    A["${__data.CPU_A.labels.server}"] --> B["CPU: ${__data.CPU_A:display}"]
    style B fill:${__data.CPU_A:color},color:#fff
Documentation
For detailed documentation, see docs/README.md.
Contributing
License
Apache License 2.0 — see LICENSE.
Third-Party Notices
This plugin bundles the following open-source software:
Package License Copyright
mermaid MIT © 2014-2022 Knut Sveidqvist
dagre-d3-es MIT © 2013 Chris Pettitt
dayjs MIT © 2018-present iamkun
lodash-es MIT © OpenJS Foundation
marked MIT © 2018+ MarkedJS
roughjs MIT © 2019 Preet Shihn
KaTeX MIT © 2013-2020 Khan Academy
stylis MIT © 2016-present Sultan Tarimo
uuid MIT © 2010-2020 Robert Kieffer
DOMPurify MPL-2.0 OR Apache-2.0 © 2024 Cure53
Full license texts are available in the NOTICES file.
Version
1.0.6 (built on 2026-04-06)
Insights
  • Adoption
    Running on 868 active Grafana instances.
  • Activity
    Last updated 15 Apr 2026.
    1 release in the past year.
Version
1.0.6
Dependencies
  • Grafana >=10.4.0
Developer
neildengg
  • 150+ data source integrations
  • Grafana Assistant - AI that correlates your data, builds queries, and answers questions
  • 10k Prometheus metrics + 50 GB logs, traces, and profiles on the free tier
  • ...and more
Create free account
