Enterprise Open source
Delete a Grafana library panel
Delete a library panel when you no longer need it.
Before you begin
  • Verify that the panel does not appear on a dashboard.
To delete a library panel:
  1. Hover over Dashboard on the left menu, and select Library panels from the drop-down options.
  2. Select a library panel that is being used in different dashboards.
    You will see a list of all the dashboards.
  3. Select the panel you want to delete.
  4. Click the delete icon next to the library panel name.
