Add a Grafana library panel to a dashboard
Add a Grafana library panel to a dashboard when you want to provide visualizations to other dashboard users.
Before you begin
To add a library panel to a dashboard:
- Hover over the + option on the left menu, then select Create from the drop-down options. - The Add panel dialog opens. ![Screenshot of the edit panel Screenshot of the edit panel]() - Screenshot of the edit panel
- Click the Add a panel from the panel library option. - You will see a list of your library panels.
- Filter the list or search to find the panel you want to add.
- Click a panel to add it to the dashboard.
