Plugins 〉TrafficLight
TrafficLight
TrafficLight Panel Plugin for Grafana
Allows a user to superimpose measurement displays ontop of picture with colour indicator.
Colors respect to the following values:
- gray: 0
- red: 1
- yellow: 2
- green: 3
TrafficLight
- Enter a URL for your background image.
- Set up some metrics (Influx and "fake data source" tested).
- Then add sensor displays ontop of the picture and tie them to the metrics.
Options
Each measurement display is linked to a metric through the metrics name or alias. If the metric returns a series of values then the last values is displayed.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing TrafficLight on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install TrafficLight from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
