Plugins 〉Image Save
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Image Save
- Overview
- Installation
- Change log
- Related content
Image Save Panel Plugin for Grafana
This plugin is a panel plugin for Grafana that allows you to save image to grafana.
Installation
To install this plugin using the grafana-cli tool:
grafana-cli plugins install mesak-imagesave-panel
Attention
This plugin directly stores image data in Grafana Database, allowing for quick and convenient addition of images to the dashboard. Please be mindful of the size of the added image data, as excessively large data can directly impact Grafana's performance.
Usage
- Add a new panel to your dashboard
- Select the Image Save Panel
- Upload your image
- Save your dashboard
Screenshots
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Image Save on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Image Save from the commandline:
Changelog
1.0.4 (release)
adjust image responsive scaling
1.0.3 (release)
add workflow
1.0.2 (release)
release file modify
1.0.1 (Unreleased)
Add Some Options
1.0.0 (Unreleased)
Initial release.
