Plugins 〉Image Save
Image Save
Image Save Panel Plugin for Grafana
This plugin is a panel plugin for Grafana that allows you to save image to grafana.
Installation
To install this plugin using the grafana-cli tool:
grafana-cli plugins install mesak-imagesave-panel
Attention
This plugin directly stores image data in Grafana Database, allowing for quick and convenient addition of images to the dashboard. Please be mindful of the size of the added image data, as excessively large data can directly impact Grafana's performance.
Usage
- Add a new panel to your dashboard
- Select the Image Save Panel
- Upload your image
- Save your dashboard
Screenshots
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Image Save on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
Marketplace plugins
This is a paid plugin developed by a marketplace partner. To purchase an entitlement, sign in first, then fill out the contact form.
Marketplace plugins
This is a paid for plugin developed by a marketplace partner. To purchase entitlement please fill out the contact us form.
What to expect:
- Grafana Labs will reach out to discuss your needs
- Payment will be taken by Grafana Labs
- Once purchased the plugin will be available for you to install (cloud) or a signed version will be provided (on-premise)
Thank you! We will be in touch.
1. Install the Panel
Use the grafana-cli tool to install Image Save from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
1.0.4 (release)
adjust image responsive scaling
1.0.3 (release)
add workflow
1.0.2 (release)
release file modify
1.0.1 (Unreleased)
Add Some Options
1.0.0 (Unreleased)
Initial release.
