Plugins 〉Business Calendar
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Business Calendar
- Overview
- Installation
- Change log
- Related content
Business Calendar for Grafana
Introduction
The Business Calendar is a Grafana plugin that elegantly displays events in a calendar format, pulling data from any Grafana-supported data source. It’s perfect for visualizing schedules, deadlines, or time-based metrics in a user-friendly way.
Check out our overview and tutorial video:
Requirements
- Version 3.x: Requires Grafana 10 or Grafana 11.
- Version 2.x: Compatible with Grafana 9.2 or Grafana 10.
- Version 1.x: Works with Grafana 8.5 or Grafana 9.
Getting Started
Install the Business Calendar plugin via the Grafana Plugins Catalog or using the Grafana CLI:
grafana-cli plugins install marcusolsson-calendar-panel
After installation, restart Grafana, then add the Business Calendar panel to your dashboard.
Features
- Multi-Language Toolbar:
- Switch between Day, Week, Month, Work Week, Year, and Agenda views.
- Jump to today’s events or navigate previous/next time ranges.
- Data Flexibility: Fetch and combine events from any data source.
- Time Range Filtering: Focus on specific periods.
- Threshold Coloring: Customize event colors with Grafana thresholds.
- Quick Links: Click events to open data links instead of a sidebar.
- Annotations: Show dashboard annotations for a selected time range.
- Localization: Supports Spanish, French, German, Portuguese, and Chinese.
Documentation
Find everything you need to master the plugin:
Section | Description |
Basic Configuration | Get started with the essentials. |
Configuration Options | Explore all customization settings. |
Features | Learn about key capabilities. |
Tutorials | Follow step-by-step guides. |
Release Notes | Stay updated on new features and fixes. |
Business Suite for Grafana
The Business Calendar is part of the Business Suite, a set of open-source Grafana plugins by Volkov Labs. Designed to tackle common business needs, these plugins offer intuitive interfaces, detailed docs, and video tutorials.
Enterprise Support
Opt for Business Suite Enterprise to unlock premium support:
- Dedicated Zendesk support team.
- Priority feature requests and bug fixes.
- In-person consultations.
- Access to Business Intelligence platform.
Feedback & Contributions
We’d love to hear from you! Get involved:
- Issues: Report bugs or suggest features on GitHub Issues.
- YouTube: Subscribe to Volkov Labs and comment on our videos.
License
Licensed under the Apache License 2.0.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Business Calendar on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Business Calendar from the commandline:
Changelog
3.9.1 (2025-03-18)
Enhancements
- Updated "There are no events in this range" message in the alert info component (#258)
- Adjusted Yearly view layout to prevent shifting with smaller panel sizes (#257)
- Enabled Yearly view to display events from previous years (#260)
3.9.0 (2025-02-20)
Enhancements
- Updated end-to-end (e2e) tests (#250)
- Upgraded to Grafana 11.5 and updated dependencies (#252)
- Enhanced release workflow to include attestation (#252)
3.8.0 (2024-10-25)
Enhancements
- Added multi-day event support in Yearly view (#243)
- Updated migration process for threshold color filters (#248)
- Improved
useRuntimeVariables
hook for Scenes dashboards (#247) - Upgraded to Grafana 11.3 and updated dependencies (#248)
3.7.0 (2024-09-15)
Enhancements
- Enhanced Yearly view to display events (#240)
- Upgraded to Grafana 11.2 and updated dependencies (#241)
3.6.0 (2024-08-19)
Enhancements
- Modified tooltip to prevent drawer opening when selecting text (#235)
- Updated date-time format to support multiple languages (#236)
- Hid event detail actions when no actions are available (#238)
3.5.0 (2024-07-25)
Enhancements
- Added event details in tooltip on hover (#217, #221)
- Introduced option to disable event time display (#223)
- Updated daily calendar view to reflect time range changes (#229)
- Reordered description fields for consistency (#230)
- Adjusted date handling to use time zone option (#227)
3.4.0 (2024-07-16)
Enhancements
- Improved E2E workflow using Docker (#211)
- Added font size configuration option (#213)
- Upgraded to Grafana 11.1 and updated dependencies (#214)
3.3.0 (2024-06-19)
Enhancements
- Enhanced variables with static datasource for time range in source dashboard (#205)
- Added support for multiple description fields (#206)
- Introduced threshold-based color options (#208)
- Added Portuguese language support in Grafana 11 (#209)
3.2.0 (2024-06-11)
Enhancements
- Updated tutorial video (#190)
- Added formatting options for event descriptions (#182)
- Improved details drawer layout (#192)
- Added support for additional time range sources (#179)
- Enhanced event format (#188)
- Updated time range in Agenda view (#196)
- Improved mouse cursor behavior in Agenda view (#200)
- Updated dependencies (#200)
- Added display of dashboard annotations (#194)
- Introduced Portuguese language support (#201)
- Localized toolbar and messages to the selected language (#203)
3.1.0 (2024-05-19)
Enhancements
- Added Agenda (List) view (#177)
- Enhanced customization for event bubbles (#178)
- Improved multi-day window handling (#183)
- Upgraded to Grafana 11 (#184)
3.0.0 (2024-05-02)
Breaking Changes
- Renamed plugin to "Business Calendar Panel"
- Replaced Legacy Calendar with Big Calendar
- Now requires Grafana 10 or 11
Enhancements
- Preserved dashboard refresh on time range changes (#167)
- Added plugin e2e tests and removed Cypress (#168, #170)
- Replaced Legacy Calendar with Big Calendar (#172)
- Prepared compatibility for Grafana 11 (#175, #176)
2.5.0 (2024-03-20)
Enhancements
- Updated styling for event detail tags (#161)
- Upgraded dependencies to Grafana 10.4 (#154)
Bug Fixes
- Fixed display of location in Month and Work Week views (#160)
2.4.0 (2024-03-07)
Enhancements
- Upgraded Big Calendar to version 1.10.3 (#150)
- Added option to select date format (#151)
- Updated ESLint configuration and refactored code (#152)
- Updated dependencies and GitHub Actions (#154)
- Added option to hide end time (#155)
Bug Fixes
- Fixed retention of calendar dates when time range is unchanged (#156)
2.3.1 (2023-11-06)
Bug Fixes
- Corrected import order for default Big Calendar styles and overrides (#143)
2.3.0 (2023-11-01)
Enhancements
- Added Yearly view (#134)
- Introduced internationalization (Spanish, French, German, Chinese) (#135, #138)
- Added default view selection option (#137)
- Enabled "scroll to time" feature in Big Calendar (#140, #141)
2.2.0 (2023-10-06)
Enhancements
- Added event location support in Big Calendar (#127)
- Improved contrast for event text colors (#129)
- Upgraded to Grafana 10.1.4 and Plugin Tools 2.0.2 (#132)
- Updated Grafana Access Policy for plugin signing (#132)
- Added dashboard timezone support for start and end times (#128)
- Added view selection options: Day, Week, Work Week, and Month (#133)
2.1.0 (2023-08-14)
Enhancements
- Added annotation type and limit options (#121)
- Upgraded to Grafana 10.0.3 (#122)
- Added language messages for Big Calendar (#123)
2.0.1 (2023-08-03)
Bug Fixes
- Fixed display of annotation options (#119)
2.0.0 (2023-07-28)
Breaking Changes
- Now requires Grafana 9.2 or 10
Enhancements
- Increased test coverage (#105)
- Introduced Big Calendar component for rendering (#106)
- Updated ESLint configuration (#106)
- Removed support for Grafana 8.5 (#110)
- Upgraded to Grafana 10.0 (#110)
- Improved event overlap handling when start and end dates are equal in Big Calendar (#112)
- Added quick links in Big Calendar (#113)
- Updated back/next buttons for Weekly and Daily views in Big Calendar (#114)
- Enhanced button styles in Big Calendar (#115)
- Improved calendar resizing in Big Calendar (#116)
1.4.0 (2023-06-10)
Enhancements
- Upgraded to Grafana 9.5.2 (#96, #101)
- Added text formatting, mappings, and overrides (#97)
- Removed unused standard options (#97)
- Increased test coverage and updated testing library (#100, #103)
- Migrated to Plugin Tools 1.5.2 (#101)
- Upgraded to Node 18 (#101)
- Added E2E Cypress testing (#102)
Bug Fixes
- Increased event spacing to prevent overflow (#96)
1.3.0 (2023-03-08)
Enhancements
- Upgraded to Grafana 9.4.3 (#87)
- Added label splitting for display in drawer (#88)
- Added annotation tags as labels (#88)
- Improved multi-day interval handling (#89)
- Enabled color display based on event or frame ID if color field is unspecified (#90)
- Added support for color schemes (#91)
- Added video configuration tutorial (#92)
Bug Fixes
- Fixed scrollable content in Day drawer (#93)
1.2.0 (2023-02-23)
Breaking Changes
- Refactoring and styles migration may introduce breaking changes. Test before upgrading in production.
Enhancements
- Added color selection for calendar entry queries (#67)
- Filtered out undefined events (#69)
- Updated CI and release workflows (#72)
- Rebuilt using Grafana 9.3.6 (#73)
- Refactored options editors to use field pickers (#74)
- Refactored Day and Events drawer (#75)
- Removed panel padding (#75)
- Updated Day view and styles (#76)
- Migrated to Styles v2 (#79)
- Aligned week start with Grafana settings (#80)
- Skipped undefined events in drawer (#81)
- Added display time option (#82)
- Updated styles and screenshot (#83)
1.1.0 (2022-12-12)
Breaking Changes
- Refactoring may introduce breaking changes. Test before upgrading in production.
Enhancements
- Updated panel options in README (#53)
- Added YouTube tutorial for Calendar with JSON API datasource (#54)
- Updated CI to Node 16 and synced with release workflow (#56)
- Upgraded to Grafana 9.2.2 (#57)
- Refactored code (#58)
- Upgraded to Grafana 9.3.1 (#59)
- Updated CI to upload signed artifacts (#60)
- Refactored panel options and increased test coverage (#61)
- Added annotation support (#8)
- Removed legacy code (#62)
- Enhanced panel options with annotations (#63)
1.0.0 (2022-10-02)
Enhancements
- Transferred maintenance to Volkov Labs (#51)
- Updated based on Volkov Labs Panel Template (#51)
- Upgraded to Grafana 9.1.6 (#52)
0.7.1 (2022-08-28)
Enhancements
0.7.0 (2022-03-09)
Enhancements
- Added quick links to follow data links on event click instead of opening a modal
- Upgraded to Grafana 8.4.3
0.6.0 (2022-01-28)
Breaking Changes
- Increased minimum Grafana requirement to 8.0 due to new theming engine
- Use v0.5.0 for Grafana versions below 8.0
- Upgrade to v0.6.0 for Grafana 8.0 or higher
0.5.0 (2021-09-06)
Enhancements
- Added data links support (#25)
- Introduced inline drawer for event details, replacing tooltips (#25)
- Note: Feedback welcome on the new design; considering a custom sidebar alternative
0.4.3 (2021-06-12)
Enhancements
- Renamed "Apply time interval" to "Apply time range" to align with Grafana
- Increased contrast for single-day events
0.4.2 (2021-05-22)
Bug Fixes
- Fixed issue where
classicColors
was still undefined (#16)
0.4.1 (2021-05-21)
Bug Fixes
- Fixed
classicColors
undefined error (#16) - Improved legibility of event text (#15)
0.4.0 (2021-05-20)
Enhancements
- Displayed event names for events starting outside the filtered day (#13)
- Added support for more calendars and colors (#14)
- Enabled line breaks in event descriptions (#11)
0.3.0 (2021-05-18)
Enhancements
- Added detailed view for individual events (#10)
0.2.0 (2021-05-09)
Enhancements
- Added multi-day event support (#1)
- Enabled display of truncated events (#6)
- Supported string and number fields for time dimensions
0.1.1 (2021-02-10)
- No changes
0.1.0 (2021-02-10)
- Initial release (not production-ready)
