Plugins 〉Business Calendar
Developer
Grafana Labs
Panel
community
Business Calendar
Documentation →
Business Calendar for Grafana
CI CD License
This project was originally contributed by Volkov Labs — thanks for all your great work!
We have republished under the same plugin ID, keeping the community signature. This means you can simply update your plugin version. A new ID would have required manual updates to your dashboards. For additional information on the changes, see the Notices.
This project is currently maintained by Grafana Labs. We welcome pull requests and will review them on a best-effort basis. If you're interested in taking on this project long-term, contact integrations@grafana.com. We're eager to work with new maintainers and eventually hand over the project.
Business Calendar is a powerful Grafana plugin that transforms your data into an intuitive calendar view. Seamlessly visualize schedules, deadlines, and time-based metrics from any Grafana-supported data source.
🚀 Features
  • Multi-Language Toolbar: Switch between Day, Week, Month, Work Week, Year, and Agenda views with ease. Navigate to today’s events or browse time ranges.
  • Data Flexibility: Integrate and display events from any Grafana data source.
  • Time Range Filtering: Zoom in on specific periods for focused analysis.
  • Threshold Coloring: Highlight events with customizable colors using Grafana thresholds.
  • Quick Links: Click events to access data links directly (bypassing sidebars).
  • Annotations: Display dashboard annotations for selected time ranges.
  • Localization: Available in Spanish, French, German, Portuguese, and Chinese.
📋 Requirements
  • Version 4.x: Grafana 11 or Grafana 12.
  • Version 3.x: Grafana 10 or Grafana 11.
  • Version 2.x: Grafana 9.2 or Grafana 10.
  • Version 1.x: Grafana 8.5 or Grafana 9.
🛠️ Installation
Get started with Business Calendar in just a few steps:
  1. Install the plugin via the Grafana Plugins Catalog or using the Grafana CLI:
    grafana-cli plugins install marcusolsson-calendar-panel
  2. Restart Grafana to load the plugin.
  3. Add the Business Calendar panel to your dashboard and configure your data source.
📚 Documentation
Explore comprehensive guides and resources to master the plugin:
SectionDescription
Basic configurationLearn the essentials to get started.
Configuration optionsDive into all customization settings.
FeaturesDiscover key capabilities and use cases.
Release notesStay updated on new features and fixes.
📜 License
This project is licensed under the Apache License 2.0.
Install on Grafana Cloud
Plugins can be installed directly from within your Grafana instance or automated using the Cloud API or Terraform.
Learn more about plugin installation
Changelog
All notable changes to the Business Calendar Panel plugin for Grafana are documented in this file.
This changelog follows the Keep a Changelog format and adheres to Semantic Versioning.
[4.2.4] - 2026-05-21
Changed
  • Debounce the Calendar remount key on panel resize to avoid full tree rebuilds on every pixel change during a drag.
  • Remove textSize from the Calendar remount key; font size changes propagate via CSS without a remount.
  • Memoize firstDay in useCalendarEvents to avoid redundant locale lookups on every render.
  • Cache Intl.DateTimeFormat instances per timezone in getMinutesOffsetFromTimeZone to avoid re-allocating the formatter on every call; use formatToParts to eliminate locale-dependent string parsing entirely.
  • Merge double .map() in useCalendarEvents into a single pass to halve intermediate array allocations per frame on every data refresh.
  • Move minutesOffset computation inside useCalendarEvents outer useMemo so the timezone offset refreshes on every dashboard time range change, fixing stale offsets after DST transitions.
  • Replace dayjs year extraction in filterEventsByYear with Date.getFullYear() to avoid constructing dayjs objects per event in year view.
  • Memoize agenda view length (daysInMonth) in BigCalendar on the current date.
  • Updated @grafana/create-plugin scaffolding from 7.0.8 to 7.6.0 (fixes TypeScript 6 baseUrl/bundler compat).
  • Externalized react/jsx-runtime and react/jsx-dev-runtime for React 19 compatibility.
  • Removed deprecated @types/testing-library__jest-dom dev dependency.
CI/CD
  • Bumped actions/create-github-app-token v3.0.0 → v3.2.0.
  • Replaced stamp-changelog publish job with check-changelog: fails if CHANGELOG.md contains an [Unreleased] section, requiring a version matching package.json before release.
  • Bumped davelosert/vitest-coverage-report-action v2.11.2 → v2.12.0.
Known Issues
  • react-big-calendar bundles react-overlays which uses ReactDOM.findDOMNode (removed in React 19). The code path is only reached for class component instances and is unlikely to be hit in practice, but a permanent fix requires an upstream release of react-overlays > 5.2.1.
Project Updates
  • Added .npmrc with ignore-scripts=true to disable lifecycle scripts and mitigate supply-chain attack risk.
  • Upgraded @grafana/plugin-e2e from 3.6.1 to 3.8.0; addPanel flow now works on Grafana 13 but setVisualization still fails due to a selector mismatch in @grafana/e2e-selectors 13.0.1. Test remains skipped on Grafana 13+ pending an upstream fix.
  • Updated patch/minor dependencies: @swc/core 1.15.33, @types/node 24.12.4, sass-loader 16.0.8, @grafana/tsconfig 2.1.0, @playwright/test 1.60.0.
  • Bumped Playwright Docker base image from v1.59.1-noble to v1.60.0-noble.
[4.2.4] - 2026-04-29
Changed
  • Updated minimum Grafana version to 12.3.0 for React 19 support.
Project Updates
  • Updated development tooling dependencies.
  • Refactored internal hooks for React 19 compatibility.
  • Improved E2E test coverage and stability on Grafana 13+.
  • Improved CI workflows: coverage reporting, PR file summaries, and automated changelog stamping on release.
  • Removed pr-files.yml workflow; GitHub's native Files changed tab supersedes it.
[4.2.3] - 2026-04-23
Changed
  • Bumped Node version requirement to 24.
  • Updated plugin build tooling (.config/ from @grafana/create-plugin v7.0.8).
  • Added missing webpack dependencies (imports-loader, webpack-subresource-integrity, webpack-virtual-modules).
  • Updated dependencies within semver ranges (Grafana 12.4.2, webpack 5.105.4, i18next 25.10.10, sass 1.98.0, etc.).
  • Removed unused dependencies (@stylistic/eslint-plugin, tsconfig-paths).
  • Simplified docker-compose.yaml to extend base config.
  • Pinned CI/CD workflows to ci-cd-workflows/v7 instead of @main.
  • Pinned Playwright Docker image to v1.59.1-noble.
  • Bumped minimum supported Grafana version to 12.0.0.
  • Upgraded @grafana/plugin-e2e from 2.x to 3.4.10 for Grafana 12.4.2 E2E compatibility.
  • Skipped React 19 preview image in Playwright E2E tests (pending upstream react-overlays fix).
  • Inlined useDashboardVariables hook and removed @volkovlabs/components dependency.
  • Removed unused grafana-dev Docker Compose service.
  • Updated patch/minor dependencies (@grafana/plugin-e2e 3.4.11, @playwright/test 1.59.1, @swc/core 1.15.24, @swc/helpers 0.5.21, sass 1.99.0).
  • Optimized Playwright config: increased workers (4 local, 2 CI), reduced retries (0 local, 2 CI).
  • Optimized Playwright Dockerfile with dependency layer caching.
Fixed
  • Added pull-requests: read permission to publish.yml so the reusable cd.yml@ci-cd-workflows/v7 workflow can run.
  • Fixed ESLint flat config compatibility with eslint-plugin-react-hooks@7 legacy plugins format.
  • Added aria-label to icon-only toolbar buttons for @grafana/ui 12.4.2 compatibility.
  • Replaced deprecated classicColors with theme.visualization.palette.
  • Typed Drawer mock props to fix no-explicit-any lint warning.
  • Replaced volkovlabs.io URLs with Grafana equivalents.
  • Fixed stale functionsRef in inlined useDashboardVariables hook.
  • Fixed reverted useRuntimeVariables import to use local useDashboardVariables hook.
Added
  • Added cspell.config.json for spell checking with missing words.
  • Added AGENTS.md with build/test commands, code style guidelines, naming conventions, testing conventions, ESLint rules, changelog policy, and branching policy.
[4.2.0] - 2025-10-23
Project Updates
  • Grafana Labs fork.
[4.1.0] - 2025-08-19
Changed
  • Updated ESLint configuration (#269).
  • Updated dashboard reload for data links (#271).
[4.0.1] - 2025-06-23
Changed
  • Revert react-big-calendar version (#268).
[4.0.0] - 2025-06-04
Breaking Changes
  • Now requires Grafana 10 or 11.
Changed
  • Updated Multi-Day Events (#264).
  • Upgraded to Grafana 12.0.1 and updated dependencies (#265).
  • Fix panel crashes on switching color scheme to single color(#266).
[3.9.1] - 2025-03-18
Added
  • Updated "There are no events in this range" message in the alert info component (#258).
  • Adjusted Yearly view layout to prevent shifting with smaller panel sizes (#257).
  • Enabled Yearly view to display events from previous years (#260).
[3.9.0] - 2025-02-20
Added
  • Updated end-to-end (E2E) tests (#250).
  • Upgraded to Grafana 11.5 and updated dependencies (#252).
  • Enhanced release workflow to include attestation (#252).
[3.8.0] - 2024-10-25
Added
  • Added multi-day event support in Yearly view (#243).
  • Updated migration process for threshold color filters (#248).
  • Improved useRuntimeVariables hook for Scenes dashboards (#247).
  • Upgraded to Grafana 11.3 and updated dependencies (#248).
[3.7.0] - 2024-09-15
Added
  • Enhanced Yearly view to display events (#240).
  • Upgraded to Grafana 11.2 and updated dependencies (#241).
[3.6.0] - 2024-08-19
Added
  • Modified tooltip to prevent drawer opening when selecting text (#235).
  • Updated date-time format to support multiple languages (#236).
  • Hid event detail actions when no actions are available (#238).
[3.5.0] - 2024-07-25
Added
  • Added event details in tooltip on hover (#217, #221).
  • Introduced option to disable event time display (#223).
  • Updated daily calendar view to reflect time range changes (#229).
  • Reordered description fields for consistency (#230).
  • Adjusted date handling to use time zone option (#227).
[3.4.0] - 2024-07-16
Added
  • Improved E2E workflow using Docker (#211).
  • Added font size configuration option (#213).
  • Upgraded to Grafana 11.1 and updated dependencies (#214).
[3.3.0] - 2024-06-19
Added
  • Enhanced variables with static datasource for time range in source dashboard (#205).
  • Added support for multiple description fields (#206).
  • Introduced threshold-based color options (#208).
  • Added Portuguese language support in Grafana 11 (#209).
[3.2.0] - 2024-06-11
Added
  • Updated tutorial video (#190).
  • Added formatting options for event descriptions (#182).
  • Improved details drawer layout (#192).
  • Added support for additional time range sources (#179).
  • Enhanced event format (#188).
  • Updated time range in Agenda view (#196).
  • Improved mouse cursor behavior in Agenda view (#200).
  • Updated dependencies (#200).
  • Added display of dashboard annotations (#194).
  • Introduced Portuguese language support (#201).
  • Localized toolbar and messages to the selected language (#203).
[3.1.0] - 2024-05-19
Added
  • Added Agenda (List) view (#177).
  • Enhanced customization for event bubbles (#178).
  • Improved multi-day window handling (#183).
  • Upgraded to Grafana 11 (#184).
[3.0.0] - 2024-05-02
Breaking Changes
  • Renamed plugin to "Business Calendar Panel".
  • Replaced Legacy Calendar with Big Calendar.
Added
  • Preserved dashboard refresh on time range changes (#167).
  • Added plugin E2E tests and removed Cypress (#168, #170).
  • Replaced Legacy Calendar with Big Calendar (#172).
  • Prepared compatibility for Grafana 11 (#175, #176).
[2.5.0] - 2024-03-20
Added
  • Updated styling for event detail tags (#161).
  • Upgraded dependencies to Grafana 10.4 (#154).
Fixed
  • Fixed display of location in Month and Work Week views (#160).
[2.4.0] - 2024-03-07
Added
  • Upgraded Big Calendar to version 1.10.3 (#150).
  • Added option to select date format (#151).
  • Updated ESLint configuration and refactored code (#152).
  • Updated dependencies and GitHub Actions (#154).
  • Added option to hide end time (#155).
Fixed
  • Fixed retention of calendar dates when time range is unchanged (#156).
[2.3.1] - 2023-11-06
Fixed
  • Corrected import order for default Big Calendar styles and overrides (#143).
[2.3.0] - 2023-11-01
Added
  • Added Yearly view (#134).
  • Introduced internationalization (Spanish, French, German, Chinese) (#135, #138).
  • Added default view selection option (#137).
  • Enabled "scroll to time" feature in Big Calendar (#140, #141).
[2.2.0] - 2023-10-06
Added
  • Added event location support in Big Calendar (#127).
  • Improved contrast for event text colors (#129).
  • Upgraded to Grafana 10.1.4 and Plugin Tools 2.0.2 (#132).
  • Updated Grafana Access Policy for plugin signing (#132).
  • Added dashboard timezone support for start and end times (#128).
  • Added view selection options: Day, Week, Work Week, and Month (#133).
[2.1.0] - 2023-08-14
Added
  • Added annotation type and limit options (#121).
  • Upgraded to Grafana 10.0.3 (#122).
  • Added language messages for Big Calendar (#123).
[2.0.1] - 2023-08-03
Fixed
  • Fixed display of annotation options (#119).
[2.0.0] - 2023-07-28
Breaking Changes
  • Now requires Grafana 9.2 or 10.
Added
  • Increased test coverage (#105).
  • Introduced Big Calendar component for rendering (#106).
  • Updated ESLint configuration (#106).
  • Removed support for Grafana 8.5 (#110).
  • Upgraded to Grafana 10.0 (#110).
  • Improved event overlap handling when start and end dates are equal in Big Calendar (#112).
  • Added quick links in Big Calendar (#113).
  • Updated back/next buttons for Weekly and Daily views in Big Calendar (#114).
  • Enhanced button styles in Big Calendar (#115).
  • Improved calendar resizing in Big Calendar (#116).
[1.4.0] - 2023-06-10
Added
  • Upgraded to Grafana 9.5.2 (#96, #101).
  • Added text formatting, mappings, and overrides (#97).
  • Removed unused standard options (#97).
  • Increased test coverage and updated testing library (#100, #103).
  • Migrated to Plugin Tools 1.5.2 (#101).
  • Upgraded to Node 18 (#101).
  • Added E2E Cypress testing (#102).
Fixed
  • Increased event spacing to prevent overflow (#96).
[1.3.0] - 2023-03-08
Added
  • Upgraded to Grafana 9.4.3 (#87).
  • Added label splitting for display in drawer (#88).
  • Added annotation tags as labels (#88).
  • Improved multi-day interval handling (#89).
  • Enabled color display based on event or frame ID if color field is unspecified (#90).
  • Added support for color schemes (#91).
  • Added video configuration tutorial (#92).
Fixed
  • Fixed scrollable content in Day drawer (#93).
[1.2.0] - 2023-02-23
Breaking Changes
  • Refactoring and styles migration may introduce breaking changes. Test before upgrading in production.
Added
  • Added color selection for calendar entry queries (#67).
  • Filtered out undefined events (#69).
  • Updated CI and release workflows (#72).
  • Rebuilt using Grafana 9.3.6 (#73).
  • Refactored options editors to use field pickers (#74).
  • Refactored Day and Events drawer (#75).
  • Removed panel padding (#75).
  • Updated Day view and styles (#76).
  • Migrated to Styles v2 (#79).
  • Aligned week start with Grafana settings (#80).
  • Skipped undefined events in drawer (#81).
  • Added display time option (#82).
  • Updated styles and screenshot (#83).
[1.1.0] - 2022-12-12
Breaking Changes
  • Refactoring may introduce breaking changes. Test before upgrading in production.
Added
  • Updated panel options in README (#53).
  • Added YouTube tutorial for Calendar with JSON API datasource (#54).
  • Updated CI to Node 16 and synced with release workflow (#56).
  • Upgraded to Grafana 9.2.2 (#57).
  • Refactored code (#58).
  • Upgraded to Grafana 9.3.1 (#59).
  • Updated CI to upload signed artifacts (#60).
  • Refactored panel options and increased test coverage (#61).
  • Added annotation support (#8).
  • Removed legacy code (#62).
  • Enhanced panel options with annotations (#63).
[1.0.0] - 2022-10-02
Added
  • Transferred maintenance to Volkov Labs (#51).
  • Updated based on Volkov Labs Panel Template (#51).
  • Upgraded to Grafana 9.1.6 (#52).
[0.7.1] - 2022-08-28
Added
[0.7.0] - 2022-03-09
Added
  • Added quick links to follow data links on event click instead of opening a modal.
  • Upgraded to Grafana 8.4.3.
[0.6.0] - 2022-01-28
Breaking Changes
  • Increased minimum Grafana requirement to 8.0 due to new theming engine.
    • Use v0.5.0 for Grafana versions below 8.0.
    • Upgrade to v0.6.0 for Grafana 8.0 or higher.
[0.5.0] - 2021-09-06
Added
  • Added data links support (#25).
  • Introduced inline drawer for event details, replacing tooltips (#25).
    • Note: Feedback welcome on the new design; considering a custom sidebar alternative.
[0.4.3] - 2021-06-12
Added
  • Renamed "Apply time interval" to "Apply time range" to align with Grafana.
  • Increased contrast for single-day events.
[0.4.2] - 2021-05-22
Fixed
  • Fixed issue where classicColors was still undefined (#16).
[0.4.1] - 2021-05-21
Fixed
  • Fixed classicColors undefined error (#16).
  • Improved legibility of event text (#15).
[0.4.0] - 2021-05-20
Added
  • Displayed event names for events starting outside the filtered day (#13).
  • Added support for more calendars and colors (#14).
  • Enabled line breaks in event descriptions (#11).
[0.3.0] - 2021-05-18
Added
  • Added detailed view for individual events (#10).
[0.2.0] - 2021-05-09
Added
  • Added multi-day event support (#1).
  • Enabled display of truncated events (#6).
  • Supported string and number fields for time dimensions.
[0.1.1] - 2021-02-10
  • No changes.
[0.1.0] - 2021-02-10
Added
  • Initial release (not production-ready).
