Plugins 〉CompareQueries
Developer
leoswing
Data Source
community
CompareQueries
  • Overview
  • Installation
  • Change log
  • Related content
CodeQL
Overview
This data source plugin enables data comparison capabilities by supporting queries from multiple data sources. It allows you to use custom time shifts to display data from different time ranges within a single graph.
Key features:
  • Compatible with Grafana 11
  • Resolves issues with undefined data points
  • Introduces support for timeShift aliases
Plugin-snapshot
Quick start
Step 1. Add a data source with what you want, such as Elasticsearch.
Step 2. Create a data source with type CompareQueries. Grafana --> Connections --> Data sources --> Add new data source, then type 'compare' to use CompareQueries plugin.
Screenshot-create-db
Step 3. Create a Visualization and using this plugin as the mixed data source.
Screenshot-mixed-db
Step 4. Create a basic query using your database, such as Elasticsearch.
Step 5. Create a comparison query with this plugin, to create multi-line time series, the query requires at least 2 fields in the following order:
  • field Query: Query field which refer to the basic query name
  • field Amount: Amount field with time range, time shift supports:s(second), m(minute), h(hour), d(day), w(week), M(month), y(year)
Screenshot-usage-comparequeries
Installing CompareQueries on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install CompareQueries from the commandline:
grafana-cli plugins install
2. Configure the Data Source
2.0.2 (2024-07-10)
Bug fixes
  • Fix Amount field validation issue when using with variable inside
2.0.1 (2024-07-04)
Features and enhancements
  • Add validation for amount input field
  • Sign plugin in Grafana plugin market, plugin details
  • Add plugin sign github action config
2.0.0 (2024-06-25)
Breaking change
  • Refactor the plugin id with leoswing-comparequeries-datasource, and signed with public signature level in Grafana.
  • Repo name refactor to comparequeries-datasource-rc
  • Package.json name refactor to leoswing-comparequeries-datasource
  • Release workflow publish the zip name to formate ${{ env.NAME }}-${{ env.TAG }}.zip
1.2.0 (2024-06-24)
  • Upgrade QueryEditor data binding logics from query property
Bug fixes
  • Fix QueryEditor data model timeShifts lost when refresh issue #2
1.1.0 (2024-06-20)
  • Suit with Grafana 11, remove filterQuery method as it should migrate, see PR
1.0.0 (2024-06-18)
Restructure repo with React based framework support.
  • Restructure codebase with React-based, which could refer to the tutorial
  • Add alias name as displayName support.
  • QueryEditor with React jsx and models supprt.
  • Use getDataSourceSrv() and getTemplateSrv() import from '@grafana/runtime' to fetch dataSourceSrv and templateSrv
  • Remove MutableFieldArrayVector from datasource, and refactor with Field and Array support.
Bug fixes
  • Solve data point undefined issue when no database is selected.
