Plugins 〉Network Weathermap
Developer
Seth Knights
Panel
community
Network Weathermap
  • Overview
  • Installation
  • Change log
  • Related content
Grafana Network Weathermap Plugin
Marketplace Downloads
This plugin brings customizeable and modern looking network weathermaps to Grafana. The design remains similar to the well known PHP Network Weathermap, while allowing for interoperability with Grafana and easy customization.
Link to the WIKI! or install the latest version. There are a lot of customization options for the weathermap, so it's recommended that you read over the wiki (at least at a glance) to best understand how to use it!
You can also download the latest version from Github directly.
Example Image 1
Other examples:
Example Image 2
Example Image 3
Example Image 4
Installing Network Weathermap on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Network Weathermap from the commandline:
grafana-cli plugins install
Changelog
All notable changes to this project will be documented in this file. See standard-version for commit guidelines.
0.4.3 (2023-07-18)
Bug Fixes
  • add try-catch calls to get series names (#46) (192dc26)
0.4.2 (2023-07-05)
Features
Bug Fixes
  • display all data on connection links (580206b)
  • link labels now hoverable (f6d1ea3)
  • temp changes no longer written to state (#61) (cb6d3e3)
  • update grafana dependency (323eaec)
0.4.1 (2023-07-05)
Features
Bug Fixes
0.3.6 (2023-03-26)
Features
  • customizable tooltip graph scaling (#50) (979868b)
Bug Fixes
  • 0 values no longer treated as null (#51) (56481a3)
  • do not assume field existence (#46) (f895bea)
  • missing bandwidth queries default back to 0 (612973e)
  • overwrite last values when query is null (#47) (f34afd2)
  • timestamp uses correct end of timerange (56b8d34)
0.3.5 (2023-01-25)
Features
0.3.4 (2022-12-13)
Features
Bug Fixes
0.3.3 (2022-10-24)
Bug Fixes
  • use Grafana's dataframe display method (fecbf17)
0.3.2 (2022-10-23)
Features
Bug Fixes
0.3.1 (2022-08-20)
Bug Fixes
0.3.0 (2022-08-19)
Features
Bug Fixes
  • basic setup correctly adds link (d3fabd7)
  • clearing all links resets node height/width (809b914)
0.2.8 (2022-06-16)
Features
  • dashboard linking on link click (#9) (74005ed)
Bug Fixes
  • file upload limits (d1f5d48)
  • image upload error handling (a26ce9b)
  • state changes merged for backwards compatability (cdc8957)
  • stop zooming outside of edit mode (29a7439)
0.2.7 (2022-05-28)
Features
Bug Fixes
  • update bug report template (9729460)
0.2.6 (2022-05-10)
Bug Fixes
  • JSON export no longer breaks map state (35eac8d)
0.2.5 (2022-05-04)
Bug Fixes
  • update plugin.json grafanaDependency (6c3505e)
0.2.4 (2022-04-23)
Features
Bug Fixes
  • assume last node color for new nodes (4369bd0)
  • grid guides consistently viewable (ab8ae51)
  • place new nodes at center of view (94d702e)
0.2.3 (2022-03-12)
Bug Fixes
0.2.2 (2022-02-27)
Features
Bug Fixes
