Plugins 〉Network Weathermap
Network Weathermap
Grafana Network Weathermap Plugin
This plugin brings customizeable and modern looking network weathermaps to Grafana. The design remains similar to the well known PHP Network Weathermap, while allowing for interoperability with Grafana and easy customization.
Link to the WIKI! or install the latest version. There are a lot of customization options for the weathermap, so it's recommended that you read over the wiki (at least at a glance) to best understand how to use it!
You can also download the latest version from Github directly.
Other examples:
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Network Weathermap on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Network Weathermap from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Changelog
All notable changes to this project will be documented in this file. See standard-version for commit guidelines.
0.4.3 (2023-07-18)
Bug Fixes
0.4.2 (2023-07-05)
Features
- background images (from urls!) (#5) (b00ad48)
- custom node icons (#60) (68d9b71)
- select and drag multipl nodes (03c8d9c)
Bug Fixes
- display all data on connection links (580206b)
- link labels now hoverable (f6d1ea3)
- temp changes no longer written to state (#61) (cb6d3e3)
- update grafana dependency (323eaec)
0.4.1 (2023-07-05)
Features
Bug Fixes
0.3.6 (2023-03-26)
Features
Bug Fixes
- 0 values no longer treated as null (#51) (56481a3)
- do not assume field existence (#46) (f895bea)
- missing bandwidth queries default back to 0 (612973e)
- overwrite last values when query is null (#47) (f34afd2)
- timestamp uses correct end of timerange (56b8d34)
0.3.5 (2023-01-25)
Features
- dashboard links open in new tab (2f45eba)
- graphs (#41, #11) (297b980)
- node-specific dashboard links (#36) (5a9f51f)
0.3.4 (2022-12-13)
Features
- configurable default link units (#34) (7a2acf7)
- expose zoom level and offsets (#32) (d9d3645)
- zoom outside of edit mode with shift key (#32) (78f0aa7)
Bug Fixes
0.3.3 (2022-10-24)
Bug Fixes
- use Grafana's dataframe display method (fecbf17)
0.3.2 (2022-10-23)
Features
- node DOWN status borders (#17) (aa7986a)
- percentage throughput on labels (#24) (68d8079)
- show all as percentage toggle (#24) (618b9e1)
- timestamp toggling (#23) (6ada467)
- variable link/arrow widths (#4) (0563f96)
Bug Fixes
- handle expressions, unlabeled queries (#12) (09f5c32)
- outline invisible color pickers (#19) (7bdc5f0)
- use field names where possible (#29) (11d1b12)
0.3.1 (2022-08-20)
Bug Fixes
0.3.0 (2022-08-19)
Features
- customizable tooltips (#15) (a5e2440)
- decimal percentages in color scale (#6) (0ce987c)
- link turns/connections (#10) (ea4abfc)
- link-specific units (8373e2a)
- load scale customization (#10) (6b636b2)
Bug Fixes
0.2.8 (2022-06-16)
Features
Bug Fixes
- file upload limits (d1f5d48)
- image upload error handling (a26ce9b)
- state changes merged for backwards compatability (cdc8957)
- stop zooming outside of edit mode (29a7439)
0.2.7 (2022-05-28)
Features
Bug Fixes
- update bug report template (9729460)
0.2.6 (2022-05-10)
Bug Fixes
- JSON export no longer breaks map state (35eac8d)
0.2.5 (2022-05-04)
Bug Fixes
- update plugin.json grafanaDependency (6c3505e)
0.2.4 (2022-04-23)
Features
- basic layout on creation (c1716f9)
Bug Fixes
- assume last node color for new nodes (4369bd0)
- grid guides consistently viewable (ab8ae51)
- place new nodes at center of view (94d702e)
0.2.3 (2022-03-12)
Bug Fixes
- clean up (02b6df0)
0.2.2 (2022-02-27)
Features
- data frame documentation (1126718)
