Plugins 〉Yugabyte
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Yugabyte
- Overview
- Installation
- Change log
- Related content
- Documentation →
Yugabyte data source
The Yugabyte data source plugin allows you to seamlessly connect Grafana to your YugabyteDB instances, enabling rich visualization and monitoring of your YugabyteDB data.
Documentation
For detailed documentation on the Yugabyte data source plugin, including advanced configuration, query syntax, and troubleshooting, please refer to the official documentation.
Contributing
We welcome contributions to the Yugabyte data source plugin! If you encounter any issues or have feature requests, please open an issue in the github repository.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Yugabyte on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Yugabyte from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
0.1.7-preview
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.265.0
0.1.6-preview
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.261.0
0.1.5-preview
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.260.1
Chore: Bump cross-spawn to 7.0.6
Chore: Change grafana/experimental to grafana/plugin-ui
0.1.4-preview
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.258.0
Chore: Bump uplot to 1.6.31
0.1.3-preview
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.251.0
Chore: Bump path-to-regexp from 1.8.0 to 1.9.0
0.1.2-preview
Chore: Bump github.com/grafana/grafana-plugin-sdk-go v0.245.0
Chore: Bump micromatch from 4.0.7 to 4.0.8
Chore: Bump webpack from 5.86.0 to 5.94.0
0.1.1-preview
Chore: Update to github.com/grafana/sqlds/v4 v4.1.0
Chore: Update to github.com/grafana/grafana-plugin-sdk-go v0.242.0
Chore: Bump fast-loops from 1.1.3 to 1.1.4
Docs: Set minimum supported Grafana version to 10.4.5
0.1.0-preview
Feature: Initial release - Unlock the potential of your data with our new data source for Grafana!
