Plugins 〉Sqlyze Datasource
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Sqlyze Datasource
- Overview
- Installation
- Change log
- Related content
- Documentation →
Grafana Sqlyze Data source
A Grafana data source plugin that connects to hundreds of datasources using one language: SQL. Connect to your favorite SQL databases, NoSQL databases, and many other non-SQL sources...and query them with SQL.
This plugin is not yet supported in Grafana Cloud.
The data source uses ODBC
This plugin has a dependency on ODBC. Windows/Linux/MacOS all support ODBC. Some dependencies may need to be installed.
Using ODBC with Linux ARM or MacOS
Install or make sure unixODBC is installed
https://www.ibm.com/docs/en/db2/11.5?topic=managers-installing-unixodbc-driver-manager
This plugin requires an ODBC driver. ODBC Drivers are available through 3rd parties. See below for a list.
Time series
To format your queries for time series, simply use the alias: as time
select date_start as time, foo, avg(bar) as bar
from foo_bar
Short list of known drivers and settings
DB2
Can be downloaded from IBM Fix Central where you can choose your DB2 Version and Platform: https://www.ibm.com/support/fixcentral/swg/selectFixes?parent=ibm%7EInformation%20Management&product=ibm/Information+Management/IBM+Data+Server+Client+Packages&release=11.5.*&platform=Mac+OSX&function=all
Driver Settings - set the path to where the driver is installed and add required settings (MacOS example below)
Setting | Example Value |
Driver | /Applications/dsdriver/lib/libdb2o.dylib |
Timeout (seconds) | 10 |
host | 127.0.0.1 |
port | 50000 |
uid | db2inst1 |
pwd | •••••••••••• |
database | sample |
Impala
- Driver: https://www.cloudera.com/downloads/connectors/impala/odbc/2-6-14.html
- Settings: https://docs.cloudera.com/documentation/other/connectors/impala-odbc/latest/Cloudera-ODBC-Driver-for-Impala-Install-Guide.pdf
Databricks
- Driver: https://databricks.com/spark/odbc-drivers-download
- Settings: https://docs.databricks.com/integrations/bi/jdbc-odbc-bi.html#odbc-driver
Third party drivers
Settings vary per driver. This plugin allows any key/value pair to support various ODBC drivers.
Grafana Enterprise
- Available with a Grafana Enterprise license
- Run fully managed or self-manage on your own infrastructure
Grafana Enterprise
Grafana Enterprise
Grafana Enterprise
Grafana Enterprise
Installing Sqlyze Datasource:
1. Install the Data Source
Use the grafana-cli tool to install Sqlyze Datasource from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v1.5.11 - 2025-02-04
- update frontend dependencies
v1.5.10 - 2025-01-10
- ⚙️ Chore: Update backend dependencies
v1.5.9 - 2025-01-06
- ⚙️ Chore: update backend dependencies
v1.5.8 - 2024-12-18
v1.5.7 - 2024-12-16
v1.5.6 - 2024-11-12
- ⚙️ Chore: Updated backend dependencies
v1.5.5 - 2024-10-03
- ⚙️ Chore: Update frontend dependencies
- ⚙️ Chore: Minimal supported Grafana version is now
10.4.8
v1.5.4 - 2024-10-01
- ⚙️ Chore: log more in test mode
v1.5.3 - 2024-09-24
- ⚙️ Chore: add some helpful logging on env variables
v1.5.2 - 2024-09-24
- 🐛 Fix: fix default time to UTC not local
v1.5.1 - 2024-09-23
v1.5.0 - 2024-09-13
- ⚙️ Chore: Update UI and documentation
v1.4.3 - 2024-08-30
v1.4.2 - 2024-06-19
v1.4.1 - 2024-04-19
- 🐛 Fix: Dynamic frame panic
v1.4.0 - 2024-04-10
- 🐛 Fix: Cross-compile on older versions of linux to lower glibc version requirements
v1.3.1 - 2024-03-13
- ⚙️ Chore: Backend binaries are now compiled with Go version
1.22.1
v1.3.0 - 2023-10-30
- ⚙️ Chore: Update sqlds and sdk to capture error source
v1.2.0 - 2023-10-24
- ⚙️ Chore: Update Grafana npm dependencies to 9.5.13
v1.1.7 - 2023-10-04
- 🐛 Fix: VariableQueryEditor - model updates without running queries
v1.1.6 - 2023-10-02
- 🐛 Fix: VariableQueryEditor - trigger model update onblur
v1.1.5 - 2023-09-08
- ⚙️ Chore: binary compiled with newest version of the plugin-sdk which fixes bugs when dealing with float32 types
v1.1.4 - 2023-06-08
- ⚙️ Chore: backend libs updated with golang:1.20.5
v1.1.3 - 2023-06-05
- ⚙️ Chore: Backend dependencies updated
v1.1.2 - 2023-05-05
- ⚙️ Chore: Backend binaries are now compiled with Go 1.20.4
v1.1.1 - 2023-04-20
- ⚙️ Chore: Backend binaries are now compiled with Go 1.20.3
v1.1.0 - 2023-01-24
- 🚀 Feature: include unixodbc libs in linux amd64 dist
v1.0.2 - 2022-12-21
- ⚙️ Chore: Backend binaries are now compiled with Go 1.19.4
- ⚙️ Chore: Backend Grafana dependencies updated to latest version
- ⚙️ Chore: Add spellcheck
v1.0.1 - 2022-07-11
- 🐛 Fix: default time to UTC not Local
v1.0.0 - 2022-06-16
- 🐛 Fix: run button position on variable page
v0.4.1 - 2022-06-09
- 🐛 Fix: set exec permission
v0.4.0 - 2022-04-29
- 🚀 Feature: Template variables
v0.3.0 - 2022-04-28
- 🚀 Feature: Infer data types
v0.0.2 - 2022-04-25
- Beta release.
