Plugins 〉Organization Panel
Developer
Blueswen
Panel
community
Organization Panel
  • Overview
  • Installation
  • Change log
  • Related content
Organization Panel
Grafana CI CodeQL Known Vulnerabilities License
Introduction
Switch Grafana organizations via dropdown menu or buttons.
Dashboard
Inspired by Organisations Panel and Business Variable Panel.
Getting Started
The Organization Panel can be installed from the Grafana Plugins catalog or utilizing the Grafana command line tool.
For the latter, please use the following command.
grafana-cli plugins install blueswen-organization-panel
License
Apache License Version 2.0, see LICENSE.
Installing Organization Panel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Organization Panel from the commandline:
Changelog
1.0.3 (2025-03-06)
  • Update plugin.json
1.0.2 (2025-03-05)
  • Update README.md
1.0.1 (2025-03-02)
  • Update LICENSE
  • Support attestation
1.0.0 (2025-03-02)
  • First release
