Plugins 〉Azure Cloud Native Monitoring
Developer
Microsoft
Application
commercial
  • Overview
  • Installation
  • Change log
  • Related content
Azure Cloud Native Monitoring Static Badge
Overview
Homepage
This Grafana App Plugin provides a seamless and enhanced monitoring experience for Azure Kubernetes Service (AKS) users. It integrates Azure, AKS, and Prometheus to offer a comprehensive view of your AKS environment.
Simplified User Experience: Users can access fully populated charts and experiences by selecting the cluster of interest. The plugin reduces the number of user inputs required, automatically discovering and populating variables such as Prometheus datasource and Log Analytics workspace.
Granular Monitoring: It displays monitoring data at various levels of granularity, from multi-cluster to individual containers, allowing users to drill down into specific areas of interest.
Curated Azure Monitoring: The plugin provides a curated Azure monitoring experience within Grafana, making it available in the public Grafana catalog and compatible with various Grafana platforms.
Enhanced Troubleshooting: It improves the AKS troubleshooting experience by providing better navigation, a range of supported visualizations, and keeping users in the same context.
Requirements
This plugin works with Azure Monitor Datasource and Prometheus datasource configured with the Azure Monitor managed service for Prometheus. Please make sure you have configured in your instance:
Permissions requirements
Regardless of the Azure Authentication method you are using, the following are the minimum required permissions that you Grafana instance needs for the resource you are trying to query data from:
  • Azure Monitor: Monitoring Reader
  • Azure Managed Prometheus: Monitoring Data Reader
Getting started
If this plugin has not yet been enabled on your Grafana instance, Click on Install then Enable. This will automatically add an entry point on your Grafana navigation bar under Apps
Grafana Navigation Bar
Simply click on it and start your troubleshooting journey!
If you are self hosting your Grafana instance and would like to see the plugin as a root item in your navidation menu, you need to add the following config in your grafana.ini file.
[navigation.app_sections]
azure-monitor-app = "root"
Contributing
Please go to our repo to learn more about how to contribute
If you would like to report an issue or provide feedback, please open a github issue
Installing Azure Cloud Native Monitoring on Grafana Cloud:
1. Install the Application
Use the grafana-cli tool to install Azure Cloud Native Monitoring from the commandline:
grafana-cli plugins install
2. Enable it
Next, log into your Grafana instance. Navigate to the Plugins section, found in your Grafana main menu.
Click the Apps tabs in the Plugins section and select the newly installed app.
To enable the app, click the Config tab. Follow the instructions provided with the application and click Enable. The app and any new UI pages are now accessible from within the main menu, as designed by the app creator.
If dashboards have been included with the application, they will attempt to be automatically installed. To view the dashboards, re-import or delete individual dashboards, click the Dashboards tab within the app page.
Changelog
1.0.0 (Unreleased)
Initial release.
