Plugins 〉Timepicker Buttons Panel
Timepicker Buttons Panel for Grafana
A Grafana panel which allows you to create a list of buttons which set specific times (retrieved from a datasource) on the dashboard's timepicker when clicked.
Compatibility
This plugin works with Grafana 7.0.0 and up.
For older versions, check out the releases page.
Installation
sudo service grafana-server stop
cd /var/lib/grafana/plugins
sudo git clone https://github.com/WilliamVenner/grafana-timepicker-buttons
sudo mv grafana-timepicker-buttons williamvenner-timepickerbuttons-panel
sudo chown grafana:grafana williamvenner-timepickerbuttons-panel -R
sudo chmod 774 williamvenner-timepickerbuttons-panel -R
sudo service grafana-server start
Usage
Display Style Configuration
The timepicker can be configured to display buttons (vertically or horizontally), or as a dropdown list.
Field Mapping
All dates and times should use UTC.
The data returned from the datasource must be formatted as a Table, not a Time Series.
The panel can be configured to indicate which fields are mapped to the button properties:
The data fields returned from the datasource should be mapped with the following panel configuration settings:
| Column | Default Value | Description |
| Time From Field | time_from | Required A UNIX Timestamp ( Number)This will set the "From" part of the time range. The value can include or exclude ms. Example: 1612413008000 or 1612413008 |
| Time To Field | time_to | Optional A UNIX Timestamp ( Number)This will set the "To" part of the time range. The value can include or exclude ms. Example: 1612413008000 or 1612413008 If this is not supplied, it will default to now. |
| Button Text Field | button_text | Optional What the text inside the button will say. If this is not supplied, it will default to a locale-formatted timestamp. |
| Primary Field | primary | Optional Field used to determine if the button will be marked with a star icon |
| Primary Value | 1 | Optional A Regex pattern to perform on the Primary Field. If matched the button will be marked with a star icon. |
Credit
Logo made by DinosoftLabs on www.flaticon.com
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Timepicker Buttons Panel on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Timepicker Buttons Panel from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Change Log
All notable changes to this project will be documented in this file.
v1.0.0
Initial Release
