Plugins 〉Business Satellite
Developer
Volkov Labs
Data Source
community
Business Satellite
  • Overview
  • Installation
  • Change log
  • Related content
Business Satellite for Grafana
Datasource
Grafana CI E2E codecov CodeQL
Introduction
The Business Satellite data source for Grafana allows retrieving data from local and remote Grafana instances via HTTP API.
Business Satellite data source | Easy access to Grafana backend | Includes Annotations tutorial
Requirements
  • Business Satellite data source 3.X requires Grafana 10.2 or Grafana 11.
  • Grafana HTTP API data source 2.X requires Grafana 9 and Grafana 10.
  • Grafana HTTP API data source 1.X requires Grafana 8.5 and Grafana 9.
Getting Started
The Business Satellite Data Source can be installed from the Grafana Catalog or utilizing the Grafana command line tool.
For the latter, use the following command.
grafana cli plugins install volkovlabs-grapi-datasource
Install Business Suite plugins in Cloud, OSS, Enterprise | Open source community plugins
Authentication
The Business Satellite Data Source requires a Grafana URL and a Token or API key to establish the connection to the organization and get relevant data.
Highlights
  • Connects to Local and Remote Grafana instances via HTTP API using API Keys and Tokens.
  • Allows getting Health information.
  • Allows retrieving Annotations, Alerts, and Data Sources.
Documentation
SectionDescription
ConfigurationExplains configuration settings for the Data Source.
ProvisioningDemonstrates how to automatically provision the Data Source.
FeaturesDemonstrates panel features.
Release NotesStay up to date with the latest features and updates.
Business Suite for Grafana
The Business Suite is a collection of open source plugins created and actively maintained by Volkov Labs.
The collection aims to solve the most frequent business tasks by providing an intuitive interface with detailed written documentation, examples, and video tutorials.
Enterprise Support
With the Business Suite Enterprise, you're not just getting a product, you're getting a complete support system. You'll have a designated support team ready to tackle any issues.
You can contact us via Zendesk, receive priority in feature requests and bug fixes, meet with us for in-person consultation, and get access to the Business Intelligence. It's a package that's designed to make your life easier.
Always happy to hear from you
License
Apache License Version 2.0, see LICENSE.
Installing Business Satellite on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Business Satellite from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Change Log
3.4.0 (2024-12-25)
Features / Enhancements
  • Updated E2E tests (#83)
  • Updated to Grafana 11.4 and dependencies (#84)
3.3.0 (2024-11-17)
  • Updated to Grafana 11.3 and dependencies (#80)
3.2.0 (2024-07-29)
Breaking changes
  • Requires Grafana 10.2 and Grafana 11
  • Added variables support in Dashboard Scene (#75)
  • Added grafana alerts with states (#76)
3.1.0 (2024-07-16)
  • Updated minimum Grafana version to 10.1.0 (#72)
  • Added get dashboards meta request (#70)
  • Added data source health check (#71, #73)
3.0.0 (2024-07-11)
Breaking changes
  • Requires Grafana 10.1 and Grafana 11
  • Update Tutorial in README (#57)
  • Update ESLint configuration and refactoring (#61)
  • Add plugin e2e tests and remove cypress (#64)
  • Prepared for Grafana 11 (#66)
  • Updated E2E tests to use Docker (#68)
  • Updated to Grafana 11.1.0 dependencies (#60, #69)
2.2.0 (2023-09-19)
  • Move API methods under feature flag to support various Grafana versions (#53)
  • Add an option to disable Alert Rules in Annotations (#55)
  • Add a values field from annotation text (#30)
2.1.0 (2023-09-10)
  • Refactor API and increase test coverage (#50)
  • Update ESLint configuration (#50)
  • Add Local mode to access local instance (#51)
  • Add Organization Users (#52)
2.0.0 (2023-07-17)
Breaking changes
  • Requires Grafana 9 and Grafana 10
  • Update to Grafana 10.0.2 (#31, #40, #45, #47)
  • Add Annotations Tutorial to README (#33)
  • Add Authentication to Getting Started (#36)
  • Add exception handling for Alert Rules in Annotations (#39)
  • Update tests with testing-library/react (#42)
  • Add tests for Components and datasource (#44)
  • Migrate to Plugin Tools 1.5.2 (#45)
  • Update to Node 18 and npm (#45)
  • Add E2E Cypress testing (#48)
1.2.0 (2023-03-30)
  • Add formatted Annotation labels for Alerts (#19)
  • Update Annotation Limit to 100 by default (#19)
  • Add Alert Rules and UID for Alerts Annotations (#20)
  • Update Scoped Variables for Annotations (#21)
  • Add Variable Support (#25)
  • Update provisioning for testing Alerts (#26, #28)
  • Add Annotations Tutorial (#29)
1.1.0 (2023-03-15)
  • Update to Grafana 9.4.3 (#13)
  • Update Bearer token plugin configuration (#13)
  • Signed as community plugin (#14)
  • Update Grafana types and description (#15)
1.0.0 (2023-03-02)
  • Initial release based on Volkov Labs Abc Data source template
  • Update README and configuration (#1)
  • Add Postgres for Alerting (#2)
  • Add Annotations (#3)
  • Update name to Grafana HTTP API (#4)
  • Improve Annotations and update to Timescale (#5)
  • Improve Data Source to check Organization (#6)
  • Add Notifications and increase Test Coverage (#7)
  • Add Annotation filters (#8)
  • Add Annotation Alert States filter (#9)
  • Add Health and Data Sources (#10)
  • Update README to prepare for the release (#11, #12)
