Plugins 〉Trino
Developer
Trino
Data Source
community
Trino
  • Overview
  • Installation
  • Change log
  • Related content
Trino Grafana Data Source Plugin
Build
The Trino datasource allows to query and visualize Trino data from within Grafana.
Getting started
Drop this into Grafana's plugins directory. To run it locally without installing Grafana, run it in a Docker container using:
docker run -d -p 3000:3000 \
  -v "$(pwd):/var/lib/grafana/plugins/trino" \
  -e "GF_PLUGINS_ALLOW_LOADING_UNSIGNED_PLUGINS=trino-datasource" \
  --name=grafana \
  grafana/grafana-oss
Features
  • Authentication:
    • HTTP Basic
    • TLS client authentication
    • Access token (JWT)
    • OAuth
  • Raw SQL editor only, no query builder yet
  • Macros
Macros support
Plugin supports the following marcos:
  • $timeFrom($column) - replaced with the lower boundary of the currently selected "Time Range" as a timestamp.
  • $timeTo($column) - replaced with the upper boundary of the currently selected "Time Range" as a timestamp.
  • $timeGroup($column, $interval) - replaced with an expression that rounds values of a column to the selected "Group by a time interval" value.
  • $dateFilter($column) - replaced with a range condition for the currently selected "Time Range" as dates, on a column passed as the $column argument. Use it in queries or query variables as ...WHERE $dateFilter($column)... or ...WHERE $dateFilter(created_at).....
  • $timeFilter($column) - replaced with a range condition for the currently selected "Time Range" as timestamps, on a column passed as the $column argument.
  • $unixEpochFilter($column) - replaced with a range condition for the currently selected "Time Range", on a column passed as the $column argument.
  • $parseTime - parse a timestamp string using the default or specified format.
A description of macros is available by typing their names in Raw Editor
Templating
Using Variables in Queries
Template variable values are only quoted when the template variable is a multi-value.
If the variable is a multi-value variable then use the IN comparison operator rather than = to match against multiple values.
Example with a template variable named hostname:
SELECT
  atimestamp as time,
  aint as value
FROM table
WHERE $__timeFilter(atimestamp) and hostname in($hostname)
ORDER BY atimestamp ASC
Disabling quoting for multi-value variables
Grafana automatically creates a quoted, comma-separated string for multi-value variables. For example: if server01 and server02 are selected then it will be formatted as: 'server01', 'server02'. To disable quoting, use the csv formatting option for variables:
${servers:csv}
Read more about variable formatting options in the Variables documentation.
Contributing
If you have any idea for an improvement or found a bug do not hesitate to open an issue or submit a pull request. We will appreciate any help from the community.
Development
See DEVELOPMENT.md for development instructions.
License
Apache 2.0 License, please see LICENSE for details.
Installing Trino on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Trino from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.0.10
  • Store access token securely
  • Update dependencies
1.0.9
  • Add support for access token (JWT) authentication
1.0.8
  • Add support for OAuth
  • Add support for annotations
  • Use UTC timestamps in macroTimeFilter
1.0.7
  • Add support for user impersonation
1.0.6
  • Revert focus change actions from last version to fix running queries
1.0.5
  • Don't execute query with every focus change
  • Fix connection error handling
1.0.4
  • Add query variable support
  • Enable alerting
1.0.3
  • Use the custom CA in the custom http client
  • Only check for client certs when TLS options are present
1.0.2
What's Changed
Add support for TLS client auth
1.0.1
Updated dependencies.
1.0.0
Initial release.
