Plugins 〉Organisations
Developer
Timo Myllymaki
Panel
community
Organisations
  • Overview
  • Installation
  • Change log
  • Related content
Organisations Panel Plugin for Grafana
This is a panel plugin for Grafana. It shows all organizations that user belongs to as navigable link buttons.
To understand what is a plugin, read the Grafana's documentation about plugins.
Installing Organisations on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Organisations from the commandline:
grafana-cli plugins install
Changelog
1.4.0 2022-08-24
Changed from Angular.js panel to React panel
1.3.0 2020-12-10
Last Angular.js version
