Plugins 〉Matomo Tracker
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Matomo Tracker
- Overview
- Installation
- Change log
- Related content
Matomo Tracking Panel
Like a tracking pixel, but it is a Grafana Panel.
This panel allows Grafana dashboard usage to be tracked using Matomo. It does only tracking and has minimal visible presence.
This is independently developed. It is not an official Matomo product, and is not affiliated with, or sponsored by, Matomo.
Requirements
Compatible with Grafana 7.x
Installation
Install by using grafana-cli
grafana-cli plugins install thiagoarrais-matomotracking-panel
Usage
Include only one panel per dashboard that should be tracked. Use the configuration editor to set the URL for your Matomo instance and your site ID.
The panel does not have any visible UI. We suggest that it should be resized to a minimal.
Credits
Sponsored by Serpro
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Matomo Tracker on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Matomo Tracker from the commandline:
Change Log
All notable changes to this project will be documented in this file.
v1.0.0
Initial Release
