Plugins 〉hackerone-datasource
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
- Overview
- Installation
- Change log
- Related content
HackerOne Datasource for Grafana
This is a backend datasource to get data about payouts, earnings and reports from HackerOne.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing hackerone-datasource on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install hackerone-datasource from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.0.4
- setup release version
1.0.1 (Unreleased)
- add reports without bounties
1.0.0 (Unreleased)
Initial release.
