Plugins 〉Streamr
Developer
Sergej Müller
Data Source
community
Streamr
  • Overview
  • Installation
  • Change log
  • Related content
Streamr data source
Streamr data source plugin for Grafana
Beam any Streamr stream to Grafana. Configure and visualize streamed data.
Features
  • Any permission-granted Streamr stream as data source
  • Stream ID optional on plugin settings, can be defined as query
  • Detection of field types *
  • Data source health check on save
Installation
  • Go to ConfigurationData Sources
  • Click Add data soruce
  • Select Streamr as data source
  • Enter Private Key and Stream ID (optional)
  • Click Save & Test
From now on Streamr can be selected as data source:
  • Go to DashboardNew panel
  • Select Streamr as Query source
Notes
  • Streamr field types aren't compatible to Grafana field types
Installing Streamr on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Streamr from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.5.0 (2021-05-03)
  • Resend data points based on Grafana dashboard time range
1.4.0 (2021-03-26)
  • Signed version
1.3.0 (2021-03-11)
  • Stream ID as query param
  • Code refactoring
1.2.2 (2021-02-05)
  • Add screenshots
1.2.1 (2021-02-05)
  • Remove versioning from release.yml
1.2.0 (2021-02-05)
  • Add ci.yml and release.yml
1.1.0 (2021-02-05)
  • Move privateKey to secureJsonData
  • Add handling for sessionToken
  • Add tryCatch to Streamr response
  • Add grafanaDependency to plugin.json
1.0.0 (2021-02-04)
  • Initial release
