Plugins 〉Button Panel
Developer
Speak Your Code
Panel
community
Button Panel
  • Overview
  • Installation
  • Change log
  • Related content
Grafana Button Control Panel
CI Grafana Compatibility Maintainability Test Coverage
This panel allows you to create buttons and define actions for them. It can be used to add control functionality to your dashboards. Actions are defined as queries to Datasources.
drawing
Multiple buttons are allowed within a single panel, they can be arranged either horizontally or vertically.
Horizontal Vertical
The query field is a JSON object, that depends on each Datasource type. You can use Grafana's Query Inspector to find out what Grafana sends to each Datasource, and copy those into the query field.
Examples
Query field to delete InfluxDB database:
  "query": "drop database \"foo\"",
  "rawQuery": true,
  "resultFormat": "time_series"
Same example with PostgreSQL:
  "rawSql": "DROP DATABASE foo;",
  "format": "table"
refId, datasourceId are automatically sent, so you don't have to set them.
Installing Button Panel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Button Panel from the commandline:
grafana-cli plugins install
Changelog
0.3.0
  • Update to Grafana 9
