Plugins 〉Trend Panel
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Trend Panel
- Overview
- Installation
- Change log
- Related content
Description
This grafana panel displays trend panels based on the data source most recent time aggregation. It is possible to tune the thresholds and to limit the number of graphics per line.
The plugin was tested with Elastic Search 7.0 as data source. The trend is computed between the last and previous date aggregation of the serie.
Screenshots
Showcase
Panel Options
Datasource
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Trend Panel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Trend Panel from the commandline:
grafana-cli plugins install
Changelog
2.0.15 (Released)
Initial grafana release.
