Plugins 〉Colored SVG Panel
Developer
Arnaud Marchand
Panel
community
Colored SVG Panel
  • Overview
  • Installation
  • Related content
SVG Panel
This panel dispays data as a colored svg using a customizable threshold. Compatible with Grafana 7.0+
Dashboard
Screenshot
Parameters
Screenshot
Installing Colored SVG Panel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Colored SVG Panel from the commandline:
grafana-cli plugins install
