Plugins 〉Status Overview Panel
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
- Overview
- Installation
- Change log
- Related content
Status Overview Panel is an ideological continuation of the Status Panel plugin, written on the latest framework supported by Grafana. The plugin's task is to display the worst status of any component based on various metrics or one of the metrics of that component. In this context, the component can be any server, application, IT system, or anything else you can think of, combining metrics into a single entity. The main feature of the plugin is the visual representation of the component's status changes. We achieve this with a large panel displaying the component's name, the display of all metrics or metrics influencing the status change, as well as a flashing effect when the status changes. Audio notifications are also planned for the future.
More info on github Status-Overview-Panel
Preview
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Status Overview Panel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Status Overview Panel from the commandline:
grafana-cli plugins install
Changelog
[v0.0.4] (dev-release)
Released at 17-06-2023
Added
- Selecting metrics by regular expression
- Replacing the name of the metric by regular expression
Changed
- Changed error display for duplicate metrics
Fixed
- Small fixes
[v0.0.3] (dev-release)
Released at 11-05-2023
- Initial release.
