Plugins 〉3D Globe Panel
The 3D Globe Panel plugin has been deprecated and is no longer maintained.
3D Globe Panel
3D Globe Panel
A Cesium.js based 3D Globe panel, with some customization options. Just define your CZML datasource in the options section and the panel will render it.
You can use any template variable you defined in your dashboard as part of the Querystring or Base URL, with two extra variables replaced by the plugin:
$timeFrom: Unix timestamp with the start of the currently selected time range$timeTo: Unix timestamp with the end of the currently selected time range
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing 3D Globe Panel on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install 3D Globe Panel from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
