Plugins 〉Quickwit
Developer
Quickwit
Data Source
commercial
Quickwit
  • Overview
  • Installation
  • Change log
  • Related content
Quickwit data source for Grafana
The Quickwit data source plugin allows you to query and visualize logs, traces, and indexed data in Quickwit within Grafana.
Requirements
You need a Quickwit standalone server or cluster.
Configuration
  1. Add a new data source in Grafana
  2. Select the Quickwit data source plugin
  3. Enter your Quickwit server URL
  4. Enter your index ID and related information.
  5. Save and test the datasource.
Features
The Quickwit data source plugin works with dashboards and explore views. Alerts are also available.
Installation
Installation on Grafana Cloud
Installation with Grafana CLI
grafana-cli plugins install quickwit-quickwit-datasource
Installation with Docker
  1. Add the plugin to your docker-compose.yml or Dockerfile
  2. Set the environment variable GF_INSTALL_PLUGINS to include the plugin
GF_INSTALL_PLUGINS="quickwit-quickwit-datasource"
Installing Quickwit on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Quickwit from the commandline:
2. Configure the Data Source
Changelog
0.3.0-beta.1
This version works only with quickwit main version (or docker edge).
  • Add support for data links (possibility to create links to other datasources).
0.3.0-beta.0
  • Add support for log context feature.
  • Better error handling.
0.2.4
What's Changed
  • Pluing is now signed
0.2.3
Fixed
  • Add licensing and notice files to respect Grafana Labs license
  • Various cleanup: remove console.log, dependency on Grafana simplejson
  • Update src/README.md
0.2.2
Fixed
  • Fix bug on template variable depending on another template variable
  • Fix bug when template variable is used with multiple values
0.2.1
What's Changed
  • Add support for template variables
  • Update provisioning datasource guide by @hoangphuocbk in https://github.com/quickwit-oss/quickwit-datasource/pull/13
New Contributors
  • @hoangphuocbk made their first contribution in https://github.com/quickwit-oss/quickwit-datasource/pull/13
0.2.0
Added
  • Add HTTP Basic Auth support
  • Clean the datasource parameters stored in the database (breaking change).
Fixed
  • Sub aggregations were broken when a sub bucket was empty. This can happen if some document have missing values on the sub field.
0.1.0
Initial release.
Added
  • Support Explore with volume an logs panels
  • Support for Dashboard
  • Support for Alerts
  • Metrics supported: 'count', 'avg', 'sum', 'min', 'max', 'percentiles', 'raw_data', 'logs'.
