Plugins 〉Parca Flamegraph
Parca Flamegraph
Parca Flamegraph Plugin for Grafana
Getting started
- Install the Parca flamegraph plugin from the Grafana plugin repository.
- Make sure that Parca datasource plugin is installed and configured in Grafana, if not, follow the instructions here.
- Configure the Parca flamegraph panel:
- Add a new panel to your dashboard.
- In the Query section:
- Select the Parca datasource.
- The
Profile Typedropdown, lists the profile types that are available on the connected Parca server. Select the profile type you want to visualize. - In the
Query Selectorfield, enter the query you want to visualize. The query selector is a PromQL like expression that is used to select the profiles that you want to visualize. For example,{job="api-server"}will select all the profiles that have the labeljobwith the valueapi-server.
- In the Visualization section on the right, select the
Parca Flamegraphvisualization. Now you should be able to see the flamegraph visualization, for the selected query. - Enter a suitable title for the panel in the
Panel Titlefield. - Save the Panel.
Configuring the Datasource
- Install the Parca datasource plugin from the Grafana plugin repository.
- In the Grafana UI, navigate to the
Configuration->Data Sourcespage. - Click on the
Add data sourcebutton. - Select the
Parcadatasource. - Enter the API URL of the Parca server in the
API Endpointfield. For example,http://localhost:7070/api. Note: Please make sure cors configuration of the Parca server allow requests from your Grafana Dashboard origin. If you Grafana dashboard is running athttp://localhost:3000, then ensure that the Parca server is started with either--cors-allowed-origins='http://localhost:3000'or--cors-allowed-origins='\*'flag. Please refer the docs. - Click on the
Save & Testbutton. If the connection is successful, you should see a greenData source is workingmessage. - Now you can use the Parca datasource in your panels.
Screenshots
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Parca Flamegraph on Grafana Cloud:
Warning
Plugin installation from this page will be removed in February 2026. Use the Plugin Catalog in your Grafana instance instead. Refer to Install a plugin in the Grafana documentation for more information.
Warning
Warning
Warning
Warning
Warning
1. Install the Panel
Use the grafana-cli tool to install Parca Flamegraph from the commandline:
grafana-cli plugins install The plugin will be installed into your grafana plugins directory; the default is /var/lib/grafana/plugins. More information on the cli tool.
Change Log
All notable changes to this project will be documented in this file. See Conventional Commits for commit guidelines.
0.0.35 (2022-12-13)
Note: Version bump only for package @parca/grafana-panel
0.0.34 (2022-12-13)
0.0.33 (2022-12-12)
0.0.32 (2022-12-12)
0.0.31 (2022-12-10)
0.0.30 (2022-12-08)
0.0.29 (2022-12-07)
0.0.28 (2022-12-06)
0.0.27 (2022-11-29)
0.0.26 (2022-11-29)
0.0.25 (2022-11-29)
0.0.24 (2022-11-24)
0.0.23 (2022-11-22)
0.0.22 (2022-11-22)
0.0.21 (2022-11-21)
0.0.20 (2022-11-17)
0.0.19 (2022-11-17)
0.0.18 (2022-11-16)
0.0.17 (2022-11-15)
0.0.16 (2022-11-14)
0.0.15 (2022-11-09)
0.0.14 (2022-11-08)
0.0.13 (2022-11-08)
0.0.12 (2022-11-08)
0.0.11 (2022-11-07)
0.0.10 (2022-11-03)
0.0.9 (2022-11-03)
0.0.8 (2022-11-02)
0.0.7 (2022-11-02)
0.0.6 (2022-10-31)
0.0.5 (2022-10-25)
0.0.2-beta.3 (2022-10-25)
0.0.2-beta.2 (2022-10-20)
0.13.0 (2022-10-20)
0.0.2-beta.1 (2022-10-20)
0.0.2-beta.0 (2022-10-20)
0.16.53 (2022-10-19)
0.16.52 (2022-10-19)
0.16.51 (2022-10-19)
Changelog
0.0.1 (Unreleased)
Initial release.
