Plugins 〉Optimiz-SevOne Plugin
Developer
Optimiz
Data Source
community
  • Overview
  • Installation
  • Change log
  • Related content
SevOne
This SevOne Grafana Datasource Plugin enables communication between Grafana and SevOne to pull Device data, Object data, Indicator data, and Indicator metrics your instance.
Setup Instructions
Step 1: Install Grafana Plugin
Download or clone the repository and move the unzipped folder into your Grafana plugins folder.
Add our plugin to the list of unsigned plugins in your Grafana configuration file then restart Grafana.
allow_loading_unsigned_plugins = optimiz-sevone-datasource
Step 2: Grafana Datasource Configuration
  1. Open Grafana Configuration => Data Sources
  2. Click on the "Add data source" Button
  3. Search for and add our "Optimiz-SevOne Plugin"
  4. Configure the data source based on fields below. All fields listed below are Required
  • URL: Enter the URL of the SevOne instance
  • Username: Enter a username that can access the SevOne instance
  • Password: Enter password of user
  1. Click on the "Save & Test" Button. If you get the message "Data source connection is successful" then the plugin is ready to use!
Query Categories
Devices
Option NameDescriptionOptionsAdditional Info
DevicesSelecting a Device will only return the data of the specified Device. If no Device is selected then the query will return all Device data.Device Name or IDNot Required for this Query Category
SizeLimits the amount of records returned to the number submitted1-10000Default is 20
PageThis option, in combination with the Size input, can be thought of as pagination for your requests. Ex. Setting a Size of 10 returns the first 10 records and to see the 10 records following those, increase your page number.0-9999Default is 0, which is the first page
Object
DevicesSelecting a Device will return all the Objects connected to the specified DeviceDevice Name or IDRequired for this Query Category
Indicators
DevicesSelecting a Device will fill in the Object field with Objects connected to the specificed DeviceDevice Name or IDRequired for this Query Category
ObjectSelecting a Object will return all the Indicators data connected to the specified Device and the specified ObjectObject Name or IDRequired for this Query Category
Indicators Metrics
ObjectSelecting a Object will fill in the Indicator field with Indicator connected to the specificed Device and the specificed ObjectObject Name or IDRequired for this Query Category
IndicatorSelecting a Indicator will return the Indicators metrics connected to the specified Device, the specified Object, and the specified IndicatorIndicator Name or IDRequired for this Query Category
Installing Optimiz-SevOne Plugin on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Optimiz-SevOne Plugin from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
1.0.0 (Unreleased)
Initial release.
