Plugins 〉michaeldmoore-tester-panel
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Panel
community
  • Overview
  • Installation
  • Related content
Installing michaeldmoore-tester-panel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install michaeldmoore-tester-panel from the commandline:
grafana-cli plugins install
