Plugins 〉Funnel
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Funnel
- Overview
- Installation
- Change log
- Related content
Funnel Panel
Grafana panel to create funnel charts
What are funnel charts?
A funnel chart is a specialized chart type that demonstrates the flow of e.g. users through a business or sales process. The chart takes its name from its shape, which starts from a broad head and ends in a narrow neck. The number of users at each stage of the process are indicated from the funnel’s width as it narrows.
Getting Started
The panel can be used with any data source that returns data frame(s) containing one numeric field per step in the funnel.
The easies way to achive this is to have one query per step (probably the most common way to query the data).
If your data, instead, is returned as one data frame with two fields. One field containing all the step labels and one field containing all the numeric values. We recommend using transformations (Rows to fields
) to transform that data into one data frame with one field per value.
The most common scenarios for this would be if you have a pre-baked view containing the data for the funnel e.g. if you have some heavy queries running on a regular basis to aggregate the data.
FAQ
Q: The percentage values looks off in my funnel, what am I doing wrong?
A: Check the standard options for your panel. Your min
value might be set to auto
which will cause Grafana to normalize the data and use the lowest value in the data set as the minimum value. Try to set this value to 0
to see if it will resolve the issue. For more details see the following issue.
Contributing
- For bugs or enhancements please create an issue.
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Funnel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Funnel from the commandline:
grafana-cli plugins install
Changelog
1.2.0
Feature: It is now possible to configure how to sort the bars in the funnel panel.
Bugfix: Added a FAQ to highlight that you might need to set min:0
in standard options if your data is normalized by minium value.
1.1.2
Improved accessability and fixed issue with white text on light background. Big thanks to https://github.com/negrel for help fixing this.
1.1.1
Making sure to keep backwards compatability with older Grafana version when using the new Stack component.
1.1.0
Upgrade github workflows to latest version and switched to npm instead of yarn.
1.0.1
Bugfix: Funnel plugin shows drop numbers as the wrong percentage #21 Bugfix: Text contrast improved for light/dark backgrounds #19 Bugfix: Data will not be repeated weirdly when refreshing dashboard #20
1.0.0
Initial release.
