Plugins 〉CSV
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
CSV
- Overview
- Installation
- Change log
- Related content
- Documentation →
CSV data source for Grafana
(NOTE: this plugin is now in maintenance mode, no new features will be added. We recommend using the Infinity data source plugin instead. If you want to get started quickly with CSV and Grafana, please read How to Visualize CSV Data with Grafana, which uses the recommended approach.)
The Grafana CSV Datasource plugin is designed to load CSV data into Grafana, expanding your capabilities to visualize and analyze data stored in CSV (Comma-Separated Values) format. Whether you have log files, historical data, or other datasets in CSV format, this plugin streamlines the process of integrating this data into your Grafana dashboards.
Documentation
For comprehensive instructions on setting up and configuring the Grafana CSV Datasource, please consult our official documentation.
Maintenance: Now the plugin is being maintained by Grafana Labs. Big thanks to Marcus Olsson for the awesome work!
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing CSV on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install CSV from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
v0.6.23 - 2025-02-07
- Update documentation about the deprecation
v0.6.22 - 2025-01-17
- 🛡️ Security:
golang.org/x/net
from 0.30.0 to 0.33.0 - 🛡️ Security: Update
grafana-plugin-sdk-go
to 0.263.0 - 🛡️ Security: Build and publish pipelines uses latest go lang version
1.23.5
which includes security fixes to thecrypto/x509
andnet/http
packages ( CVE-2024-45341 and CVE-2024-45336 ). More details can be found here
v0.6.21 - 2024-10-30
uplot
to 1.6.31
v0.6.20 - 2024-10-18
to 0.255 - 🛡️ Security: Bump
dompurify
from 3.1.0 to 3.1.6 - 🛡️ Security: Bump
path-to-regexp
from 1.8.0 to 1.9.0
v0.6.19 - 2024-09-03
- 🛡️ Security: Bump
micromatch
from 4.0.5 to 4.0.8 - 🛡️ Security: Bump
webpack
from 5.86.0 to 5.94.0 - 🛡️ Security: Bump
fast-loops
from 1.1.3 to 1.1.4 - 🛡️ Security: Bump
ws
from 8.14.2 to 8.17.1 - 🛡️ Security: Bump
braces
from 3.0.2 to 3.0.3
v0.6.18 - 2024-05-14
- ⚙️ Chore: Updated the eslint-plugin-prettier dependency
v0.6.17 - 2024-04-18
- ⚙️ Chore: Bump grafana-plugin-sdk-go from
v0.220.0
tov0.225.0
- ⚙️ Chore: Updated grafana frontend runtime dependencies
v0.6.16 - 2024-04-08
v0.197.0
tov0.220.0
v0.6.15 - 2024-03-07
- ⚙️ Chore: Build with go 1.22
v0.6.14 - 2024-02-14
- ⚙️ Chore: Maintenance
v0.6.13 - 2024-02-14
- 🛡️ Security: More robust URL handling: disallow changing the configured hostname in the query editor ( CVE-2023-5122 )
v0.6.12 - 2023-12-19
- ⚙️ Docs: Documentation website moved from github pages to grafana.com/docs/plugins page
- ⚙️ Chore: Updated grafana-plugin-sdk-go from
v0.193.0
tov0.197.0
v0.6.11 - 2023-11-21
- Feature: Update configuration page to follow best practices
- ⚙️ Chore: Upgrade grafana-plugin-sdk-go to latest
- ⚙️ Chore: Added lint github workflow
- ⚙️ Chore: Update legacy form styling
- ⚙️ Chore: Update readme and documentation
v0.6.10 - 2023-10-24
- 🐛 Fix: More robust local file mode handling
v0.6.9 - 2023-10-19
- 🐛 Fix: Correct query field behavior on older Grafana versions
- ⚙️ Chore: Upgrade dependencies
v0.6.8 - 2023-10-18
v0.6.7 - 2023-10-09
- Added feature tracking
v0.6.6 - 2023-08-23
- 🐛 Fix: Consistently apply field names
v0.6.5 - 2023-05-03
- ⚙️ Chore: backend binaries are now compiled with go 1.20.4
v0.6.4 - 2023-04-19
- ⚙️ Chore: backend binaries are now compiled with go 1.20.3
v0.6.3 - 2021-12-03
- ⚙️ Chore: backend binaries are now compiled with go 1.19.3
- ⚙️ Chore: frontend npm dependencies updated
- ⚙️ Chore: added spellcheck
v0.6.2 - 2021-10-14
- Fixed the broken docs and links
v0.6.1 - 2021-06-22
Bug fixes
- allow_local_mode accepts any value
v0.6.0 - 2021-06-21
Enhancements
Disable local mode by default. To use local mode, allow it in your grafana.ini:
[plugin.marcusolsson-csv-datasource] allow_local_mode = true
v0.5.0 - 2021-03-21
Enhancements
- Improved query editor with support for HTTP params, headers, and body.
- Add support for relative paths (#69)
- Add support for decimal separators (#43)
- EXPERIMENTAL: Add support for regular expressions in field names (#68). Must be enabled in the Experimental tab in the query editor.
Bug fixes
- BREAKING: Remove default Accept header (#56). If your data source expects
Accept: text/csv
on the request, you now need to add it yourself in the Params tab.
v0.4.1 - 2021-03-21
Bug fixes
- Wrong data format is detected
v0.4.0 - 2021-03-21
Enhancements
- Add support for annotation queries
- Add support for variables queries (#30)
- Upgrade @grafana/* packages
- Upgrade Grafana Go SDK
v0.3.3 - 2021-02-05
Bug fixes
- Default to HTTP if no storage type has been set
v0.3.2 - 2021-02-03
Bug fixes
- Allow lazy quotes (#17)
v0.3.1
Enhancements
- Update grafana-plugin-sdk-go to v0.83.0
Bug fixes
- Ignore empty custom HTTP headers
- 🐛 Fix: duplicate JSON tag for TLS skip verify
v0.3.0
Enhancements
- Add ARM support (#13)
Bug fixes
- Windows: Paths with backslashes don't work (#14)
v0.2.0
Enhancements
- Add support for local CSV files (#6)
- Add a default Accept header for text/csv
v0.1.0
Initial release. Not fit for production use.
