Plugins 〉Word cloud
Developer
Raúl Speroni
Panel
community
Word cloud
  • Overview
  • Installation
  • Change log
  • Related content
Marketplace Downloads
☁️ WordCloud Panel Plugin
⚠️ Unmaintained and looking for a new owner ⚠️
I no longer have the time to maintain this plugin and would love for someone to take it over and continue development.
If you are interested, please comment in this issue 🙏
This is a Wordcloud/Tagcloud panel for Grafana 7.0+, using the amazing library react-wordcloud
This was boostraped using the new @grafana/toolkit
Screenshot with query
Features
You can find features and personalization options here
Usage
You need to configure a datasource so that the query returns a list of tokens and group the result by terms. You should change the names of word, and count fields in the options tab of the plugin according to your query, if you don't default fields with matching types present in your query will be used. The amount of words is configured in the datasource settings. In those settings is also important that you choose "Order by: Doc Count".
Every other settings for the wordcloud can be changed in the plugin options tab.
ToDo
It would be really nice to use the library's available callbacks to filter grafana dashboard data when a word is clicked. I haven't found a neat way to do this yet. Issue #5
Installing Word cloud on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Word cloud from the commandline:
grafana-cli plugins install
Change Log
All notable changes to this project will be documented in this file.
v1.2.3
Stopwords and automatic release with github actions
v1.0.0
Initial Release
