Plugins 〉Neo4j Datasource
Dependencies
Grafana
Developer
Last updated
Get 30% off tickets! Explore sessions covering OpenTelemetry, Prometheus, & Loki, discover Grafana 12's latest features, and more.
Register
After last year's record sellout, our biggest community event is headed to Seattle on May 6-8! Discover what's new in Grafana 12, learn from 20+ talks covering Prometheus, OpenTelemetry, & Loki, and much more.
- Grafana, of course
- 10k series Prometheus metrics
- 50 GB logs
- 50 GB traces
- 2,232 app o11y host hours
- ...and more
No credit card needed, ever.
Become a Champion
Helping others embodies the spirit of open source, and we want to celebrate your invaluable contributions.
Become a ChampionGolden Grots
Submit your dashboardBecome a Contributor
- Reduce metric cardinality by 30-50%
- Pay only for metrics you use
- Centralize control over your data in Grafana Cloud
Gain insight into unused metrics and optimize metric cardinality with the new cardinality management dashboards and Adaptive Metrics
Neo4j Datasource
- Overview
- Installation
- Change log
- Related content
Neo4j DataSource for Grafana
Allows Neo4j to be used as a DataSource for Grafana
Configure Data
Configure Neo4j as DataSource
Query Data
Query Neo4j DataSource with Cypher Query Language and display as Table
Query Neo4j DataSource with Cypher Query Language and display as Graph
Links
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
Installing Neo4j Datasource on Grafana Cloud:
1. Install the Data Source
Use the grafana-cli tool to install Neo4j Datasource from the commandline:
grafana-cli plugins install
2. Configure the Data Source
Changelog
All notable changes to this project will be documented in this file.
The format is based on Keep a Changelog, and this project adheres to Semantic Versioning.
[1.3.2] - 2024-05-28
Changed
- Update neo4j-go-driver to v5.20.0
[1.3.1] - 2023-08-02
Changed
- Set appropiate Grafana minVersion
- Pass context from grafana api to neo4j for better handling of timeouts and query cancelations.
[1.3.0] - 2023-07-31
Added
- Grafana 10 Support
- CodeEditor with Syntax Highlight
- Option to format result for nodeGraph visualization
Changed
- Reduced Loglevel to Debug
- Replaced deprecated Neo4J Driver methods
[1.2.0] - 2023-06-11
Changed
- Updated Grafana Plugin Toolkit
- Updated Neo4J Driver to neo4j-go-driver v5.9.0
Fixed
- #14: Error for null-value attribute
[1.1.0] - 2022-02-28
Changed
- Use official name Neo4j instead of Neo4J
- Use neo4j logo with blue background to support both dark and light theme. Logo was barely visible with the light theme.
- Catch errors with connection details and prevent errors with internal network informations
- Caching Neo4j driver in the backend
[1.1.0-beta]
Added
- Changed to Backend Plugin
- Queries can now be executed in variables (Issue #3)
- neo4j password is stored and encrypted in secureJsonData
[1.0.1]
Changed
- Change Organisation name
[1.0.0]
Initial release.
