Plugins 〉SPC Chart
Developer
Kenso Software
Panel
community
SPC Chart
  • Overview
  • Installation
  • Change log
  • Related content
SPC Chart
Welcome to the KensoBI SPC Chart panel for Grafana. This plugin enables you to easily create statistical process control (SPC) charts, including Xbar-R, XbarS, and XmR charts. It automatically calculates and displays control limits, with options to add your own custom limits. Additionally, you can group your samples into subgroups and aggregate them using methods such as moving range, range, mean, or standard deviation.
Main
Available Options
  • Xbar-R, XbarS, and XmR Charts: Create various types of SPC charts with a single click.
  • Automatic Control Limits: LCL (Lower Control Limit), UCL (Upper Control Limit), and mean are automatically calculated and displayed.
  • Custom Limits: Add your own limits for more tailored analysis.
  • Subgrouping: Group your samples into subgroups for analysis.
  • Aggregation: Aggregate your data by moving range, range, mean, or standard deviation.
Documentation
Please see the full panel documentation at KensoBI Docs.
NOTE: The plugin comes with sample provisioned dashboards. Build and start the plugin to see them.
Getting Help
If you have any questions or feedback, you can:
Your feedback is always welcome!
License
This software is distributed under the Apache License.
Notes
Copyright (c) 2024 Kenso Software
Installing SPC Chart on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install SPC Chart from the commandline:
grafana-cli plugins install
Changelog
2.0.0
New Features:
  • Complete panel rewrite for improved performance and functionality.
  • Added support for XmR chart creation.
  • Added support for Custom Control Lines to pull dynamic values from Feature Series.
  • Brand New SPC Editor: A completely redesigned editor for setting up and customizing SPC charts with an intuitive user interface.
  • Threshold Colors: Ability to add color thresholds to every control line for better visualization.
  • Multiple Series Support: Enhanced functionality to handle multiple data series.s
  • Customization Options:
    • Customization of legend, tooltip, axis, and graph styles.
    • Introduced a subgroupSize dashboard variable to control subgroup size across multiple panels.
Enhancements:
  • Improved SPC calculations: Enhanced accuracy in statistical process control.
Changes:
  • License Update: Changed from Apache 2.0 to AGPL-3.0-only.
Compatibility:
  • Now supports Grafana 11.
1.0.3 (2024-04-16)
Bug fixes
  • Compatibility issue with Grafana 10.4.x (undefined reading 'Area') has been resolved.
  • Bug with displaying colors in constants has been fixed.
Features and enhancements
  • Ability to enter custom Sample size value has been added.
  • New chart display styles: lines, smooth line, points, bars.
  • Example demonstrating how to build a SQL query and use constants on a chart. See documentation for more information.
1.0.2 (2024-01-20)
  • Fix scaling of panel options.
  • Fix deprecated values.
  • Add backward compatibility to Grafana >=9.5.7.
  • Add ability to enter additional constants columns taken from the database using SQL entered as Table. See documentation for more information.
